Fuel pressure gauge
Old Feb 10, 2008 | 05:19 PM
NJ Diesel's Avatar
NJ Diesel
Default Fuel pressure gauge
Just had the original lift pump on my 99 CTD replaced at 128,000 miles. They had to go to with a in tank lift pump vs. a motor mounted one as I had. I realized the old one was going when I couldn't hear it cycle & pressurize. I can barely hear the in tank one now. The question is: thoughts about a fuel pressure gauge as an indicator for any future problems. Most people I've asked think 1.-the in tank system will last a very long time or 2.-a pressure gauge is a waste.
I'm interested in your thoughts on this as well as the different types of mounts, pillar, above dash, in dash, below dash, brands to look for or avoid and costs.
I realize I got lucky this time with the VP44, I'm not looking to roll the dice again......
Old Feb 10, 2008 | 08:23 PM
roadking096's Avatar
roadking096
Default RE: Fuel pressure gauge
I only have a FP gauge so I mounted it in dash. I made a mount like this one. http://www.genosgarage.com/prodinfo....DG-01FACE-9902 It goes in the cubby below the air bag switch. I ran a mechanical gauge with an isolator. I've got maybe $80 in the set up. I'd go out and take a photo, but it's about 6 degrees out there now. They also make one that goes on the column if you prefer.
Old Feb 10, 2008 | 09:34 PM
steve05ram360's Avatar
steve05ram360
I'd definately do a fp gauge... I'll be installing a walbro kit on my truck soon and will be adding a gauge to my indash cluster and moving the boost up to the pillar.
Old Feb 10, 2008 | 11:19 PM
dodgewithstacks's Avatar
dodgewithstacks
i've got a fp guage in mine as well, i believe its worth having, i've got the 3 guage on the pillar (boost, fuel pressure, and egt)
Old Feb 11, 2008 | 02:01 AM
Mayfair's Avatar
Mayfair
Since you have a VP-44 injection pump, a fuel pressure gauge isn't a luxury, I'd say it's a MUST !! I think it's just as inportant as a water temp gauge. If it's the only gauge you get, that collumn gauge holder is pretty cool.
Old Feb 11, 2008 | 05:17 PM
NJ Diesel's Avatar
NJ Diesel
Thanks for all the ideas.....Mayfair, I looked in Jegs & Summitt, who makes that column set-up you showed?
Old Feb 11, 2008 | 07:29 PM
burban2002's Avatar
burban2002
Take a look here http://www.genosgarage.com/prodinfo....er=GM-DG-15012. Not too expensive either.
Old Feb 11, 2008 | 09:08 PM
dasnake's Avatar
dasnake
i put the egt,boost, and tranny on the post, i put the pressure gauge on the column like mayfair posted, my opinion, can't be to safe, good luck.
Old Feb 11, 2008 | 10:59 PM
burban2002's Avatar
burban2002
Dasnake, how do you like that? Does it look cluttered around the dash?
Old Feb 12, 2008 | 03:50 AM
finny's Avatar
finny
yah dasnake is there any way you can get some pictures of the colum mount up?
