block series
Old Feb 27, 2008 | 07:02 PM
justviper1's Avatar
justviper1
Default block series
i looked today to see if my 01 had the dreaded 53 block in it and believe that the numbers on it were 55. it was really hard to see. if there is a 55 series are there any known weaknesses or problems that i should be aware of? Thanks a lot for any help!
Old Feb 27, 2008 | 07:43 PM
Drew's Avatar
Drew
Default RE: block series
nope. . .I believe 53's were the only ones with the issues, I do believe 54-56's are also made in brazil just like the 53's, however those are the newer revisions that have a thicker wall.
Old Feb 27, 2008 | 08:01 PM
woligator's Avatar
woligator
where i need to look for that number drew?
Old Feb 27, 2008 | 08:39 PM
12valveman's Avatar
12valveman
hey woligator it is on the left front the block. get under and look it is right under the ps pump and vaccum pump area it is a raised stamping let me know if that helped
Old Feb 27, 2008 | 08:59 PM
Drew's Avatar
Drew
the blocks made in brazil have numbers you can see quite well. however there were some blocks made in mexico. the casting number on the block is very small and generaly unable to be read. the casting of these blocks have proven to be considerably stouter than the brazil cast blocks. BTW, the mexican blocks are also considerably heavier.
Old Feb 27, 2008 | 10:09 PM
lilfroger's Avatar
lilfroger
ORIGINAL: Drew
I don't know if the fact you know this information should scare me or just flat impress me....Drew have we told you lately how much we appreciate you?
Old Feb 27, 2008 | 10:22 PM
bekim's Avatar
bekim
Code 53 blocks came in 99 and 00 model years. The blocks tend to crack on the rear passenger side.
Mike
Old Feb 27, 2008 | 10:33 PM
Drew's Avatar
Drew
ORIGINAL: lilfroger
ORIGINAL: Drew
it sucks having a photographic memory where not all the film quite develops properly.[:@]
Old Feb 28, 2008 | 01:44 AM
Mayfair's Avatar
Mayfair
Here ya go ...
http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
The repair
http://www.locknstitch.com/cummins_5_9_block.htm
Old Feb 28, 2008 | 08:16 AM
CowboyBob's Avatar
CowboyBob
I have a 53 block with 177k on it and have not had any problems with it yet.
Now that I have said that twice in one day on DF, I expect it to crack at any moment.
