should i do the clutch myself?
Old Mar 10, 2008 | 10:13 AM
Drew's Avatar
Drew
Default RE: should i do the clutch myself?
the NV4500HD is not that bad. . .a medium duty jack will handle it just fine. . .
the NV5600 is a BEAST!!!!! you will do yourself good to get the biggest, beefiest one you can find since it weighs more than the engine in my toyota.
Old Mar 10, 2008 | 10:17 AM
burban2002's Avatar
burban2002
Drew, dont you think it would be a good idea to turn the flywheel anyways? It would suck to get it all buttoned up, just to have to pull it apart again.
Old Mar 10, 2008 | 10:29 AM
Methos's Avatar
Methos
Any idea on the G56 weight?
Old Mar 10, 2008 | 10:39 AM
Drew's Avatar
Drew
should it be turned. . .that depends on the condition of the surface of the flywheel. I havent turned my toyota and dont plan on it since it is still flat against a machinist rule. granted theres a little rust on it, but that can be taken off with some fine sanding over the whole surface. should I turn it. . .probably, but I need to get the thing in this weekend. I need to have the emissions done on it so I can renew my tag.
no emissions checks for Diesels in Georgia. . .or atleast last I checked. if there are then smarty #0[8D]
Old Mar 10, 2008 | 10:40 AM
Drew's Avatar
Drew
G56 weight. . .I'm not certian. . .however I do know it is not as heavy as the NV5600, but a bit heavier than the 4500.
