tire rotation
Old Apr 10, 2008 | 03:52 AM
bpmills's Avatar
bpmills
Default tire rotation
Hi guys, took my 2008 mega cab dually in today to the dealer for its first oil change since the dealer paid for it. My question to the service manager was how to you rotate the 6 tires, for which he had no answer. So I thought I would ask the experts (you guys). And do you ever add the spare tire into the mix??
Thank you, Burt Mills
Old Apr 10, 2008 | 07:06 AM
Drew's Avatar
Drew
Default RE: tire rotation
for the dually's, the outer tire goes to the front, the front tire goes to the inside, and the inside tire gets turned around to the outside. . .I think thats how it goes.
Old Apr 10, 2008 | 07:48 AM
KenZ's Avatar
KenZ
Yep, kinda like that. I have the dealer do mine every other oil change. The outside right rear goes to the front left, the outside left rear goes to the front right (criss cross). The two front tires stay on the same side just move to the back inside. The inside tires move to the outside but have to be broken down and the wheel turned 180' and remounted so as the tire rolls in the same direction. I believe I said that right.
Old Apr 10, 2008 | 07:50 AM
Bigriver's Avatar
Bigriver
Most of the time I don't bother with it, but the last time they were rotated, only one rear side per rotation goes up front. For example, both fronts would go back to the left rears. (Yes, one of the tires would be reversed.) Next time use the right rears. I always thought that reversing a tires rotation would screw with the steel belts, but apparantly not, so said the tire shop that did the work.
Old Apr 10, 2008 | 12:01 PM
92oilburner's Avatar
92oilburner
now aren't you glad you asked? you got 3 different answers![&:] now even I am more confused than before. Anybody bother to read the owners manual?
Old Apr 10, 2008 | 02:02 PM
Mayfair's Avatar
Mayfair
I never realized that the inside rear tire also had a fancy rim like the outside rear tire. I just always thought they had an ugly steel wheel in there.
Old Apr 10, 2008 | 02:28 PM
QUACKSTACKER's Avatar
QUACKSTACKER
ORIGINAL: KenZ
this is how i have always heard and seen it done on duallys.
Old Apr 10, 2008 | 03:38 PM
Bigriver's Avatar
Bigriver
ORIGINAL: Mayfair
Well, all the stock rims are the same style, plain jane steel. What you're seeing on the outside is beauty rings, or simply, chrome hub caps. That way when you rotate the tires, the caps will fit any which rim that happens to be on the outside.
Old Apr 10, 2008 | 07:10 PM
nickcoletti's Avatar
nickcoletti
sounds alot like that game dance revolution
Old Apr 10, 2008 | 07:57 PM
reed's Avatar
reed
Somehow it doesn't surprise me that you'd play that game
ORIGINAL: nickcoletti
