Power Puck/Smarty
Old Apr 10, 2008 | 04:20 PM
CutterW's Avatar
CutterW
Default Power Puck/Smarty
Can you stack them? I have a power puck and a friend who sold his truck is willing to give me a hella a deal on a Smarty and was wondering if you can stack them. I know the Puck is fueling, but unsure of the Smarty.
Old Apr 10, 2008 | 06:44 PM
CutterW's Avatar
CutterW
Default RE: Power Puck/Smarty
If they are unstackable am I able to use the smarty on two vehicles because I read its a plug, tune, unplug. If not put puck on our Dually and keep Smarty for myself. I've never really thought about stacking but it would be nice to learn what can and cant be done before I tear sh*t up.
Old Apr 10, 2008 | 06:53 PM
lilfroger's Avatar
lilfroger
From what I understand the smarty vin locks it's programs. So you can only run it on one truck at a time. You'd have to return the dually to stock to put it on yours.
Old Apr 10, 2008 | 07:01 PM
nickcoletti's Avatar
nickcoletti
im sure you can stack being that the smarty has a timing setting BUT dont make any desions off that, im sure others will tune in with better information.
as far as 2 trucks at once on a smarty, i know that cant happen. it remembers the vehicle code or what ever its called and wont go onto another vehicle untill the device is turned back to stock on the truck that was running a program.
Old Apr 10, 2008 | 07:50 PM
CutterW's Avatar
CutterW
Then see what it does stacking and if to much put Puck on Dually and Smarty on my truck.
Old Apr 10, 2008 | 09:10 PM
dirtydodge02's Avatar
dirtydodge02
That's good to know about the Smarty. I had only gathered that it VIN locked if you used the tire adjuster thing.
Old Apr 10, 2008 | 09:18 PM
CutterW's Avatar
CutterW
Smarty changes the tire size/speedometer? Damn, that makes me happy.
Old Apr 10, 2008 | 09:22 PM
dirtydodge02
Only Smarty Sr. IIRC. Don't think Jr. will
Old Apr 10, 2008 | 09:50 PM
Drew's Avatar
Drew
the Jr will also adjust the speedo
if the puck is a box and not a programmer then yea, they will work together. load smarty up then adjust the puck up.
as long as smarty has been put back to stock, it can be used on any vehicle of that generation. you can even use a loaded smarty to view CEL's and adjust tire sizes on other trucks.
Old Apr 10, 2008 | 11:15 PM
nickcoletti
it just about sounds like smarty will do everything but your laundry GET ONE!!!!!!
