Backspacing
Old Apr 20, 2008 | 07:59 PM
Az2500Cummins08's Avatar
Az2500Cummins08
Default Backspacing
Now that I have found the wheel I want, I don't know how much backspacing I need. can anyone help me out? Here is a site that has all the info.
http://www.4wheelcustoms.com/Products.asp?Cat=1417
Old Apr 20, 2008 | 08:02 PM
firemedic740's Avatar
firemedic740
Default RE: Backspacing
Az, I was told a 6" BS is like factory, which is like a -30mm offset. At least I think. Ill try to find the correct info for you.
Old Apr 20, 2008 | 08:08 PM
Az2500Cummins08
thanks. I dont understand the whole backspacing thing really. So I have no Idea where to start. I know the smaller number, the more the wheel sticks out. Thats basically it.
Old Apr 20, 2008 | 08:22 PM
firemedic740
Hopefully these will help about backspacing and offset.
http://www.discounttire.com/dtcs/infoWheelOffsets.dos
https://www.rsracing.com/tech-wheel.html#backspace
Old Apr 20, 2008 | 08:58 PM
MAB_CTD_4X4's Avatar
MAB_CTD_4X4
Stock wheels are 6.25" backspacing +40mm offset
You need a wheel with 6" to 5.5" backspacing for it not to rub with 35" with a leveling kit. I just ordered a new set of rims with 5.5" bs and they hit the edeg of my bushwackers when turning if I didn't have the fender flares on I don't think they would hit at all but solving that problem with some of Thuren Fab's 1/2" longer control arms...
Old Apr 20, 2008 | 09:35 PM
Az2500Cummins08
Would a 4.75 backspacing work? Thats the highest I can find in the wheel I want. http://www.4wheelcustoms.com/Products.asp?Cat=1417
Old Apr 20, 2008 | 09:58 PM
dirtydodge02's Avatar
dirtydodge02
It will work, however that shallow of a backspacing can put additional stress on the axles because of the way the leverage works out. Not sure (but highly doubt) that you'll be able to add more stress than that truck can handle. IMO, they'll work. And you're right, they will stick out further. Mine are 5.39", not much more than half an inch difference.
Old Apr 20, 2008 | 10:13 PM
Az2500Cummins08
Hmm, I wonder what the point to them making the backspacing so short is? The backspacing I need is available in 18 and 20 inch wheel, but that doesnt really help me. I will try to email pro comp and see if they make can make the wheel with the backspacing I need.
Old Apr 20, 2008 | 10:16 PM
dirtydodge02
Never woulda thought of asking them... Good call!
Old Apr 21, 2008 | 07:24 AM
Little Foot's Avatar
Little Foot
If you want to clear 37's on a 6" lift you should have a back spacing of:
This system will accommodate up to a 37” tall tire mounted on an 8” wheel with a minimum
of 4-5/8” backspacing. The use of a wider wheel and / or a wheel with less backspacing
than specified may result in tire-to-fender contact.
I ran a 10" wheel and made contact with 35's.
