Exhaust tips
Old Apr 30, 2008 | 11:00 PM
justviper1's Avatar
justviper1
Default Exhaust tips
im starting another project on the truck. because of the way that the exhaust is run i cannot put my hitch on the truck. i am going to have an exhaust guy cut the pipes off and turn them out behind the rear wheels the only thing is that i need some new tips. where is a good place to find stainless tips. the ones that are on it now are chrome plated and they are peeling and look horrible. thanks for any help.
[IMG]local://upfiles/76119/EF700151ACAF40C1918331F90D68F46D.jpg[/IMG]
Old Apr 30, 2008 | 11:21 PM
dirtydodge02's Avatar
dirtydodge02
Default RE: Exhaust tips
http://www.mbrp.com/
Old May 1, 2008 | 12:13 AM
agargano98's Avatar
agargano98
i have the MBRP 4" inlet-5" outlet dual wall, slant cut, polished stainless. no discoloration, peeling anything. they are 1 year old and still look new. got it off ebay for $35
Old May 1, 2008 | 01:49 AM
justviper1's Avatar
justviper1
i found these at geno's and wondered if you guys thought that they would hold up since i am in the north and if they would look good behind each rear wheel?
Old May 1, 2008 | 02:39 AM
Mayfair's Avatar
Mayfair
Why can't you re-use what you have?
Old May 1, 2008 | 08:08 AM
cujo's Avatar
cujo
ORIGINAL: justviper1
I have that same tip from Geno's, has only gone through one Maryland winter so far, but it's holding up good. A little cleaning wax and it still shines up good. Other than soot, no discoloration.
Old May 1, 2008 | 09:49 AM
justviper1's Avatar
justviper1
i can't reuse what i have because first i want it coming straight out behind the wheels and not down and also becaue they are chrome plated and are peeling badly and look really bad! thanks cujo on the input. my truck usually doesn't see the winter very much since it isn't my daily driver but i still want the tips to last.
Old May 1, 2008 | 11:52 AM
agargano98's Avatar
agargano98
here is a pic of mine
[IMG]local://upfiles/80221/30361A0C536547D4967E14ABAA97BCC7.jpg[/IMG]
Old May 2, 2008 | 01:01 AM
justviper1's Avatar
justviper1
looks good. mine are goin to come out both sides and at a slight downward angle. this way the pipe will still be mostly hidden behind the body but the tip will stick out nicely.
Old May 2, 2008 | 01:40 AM
Mayfair's Avatar
Mayfair
The next time I need an exhaust, this is how I'm rollin ...
