Kore leveling kit update.......
Old May 10, 2008 | 08:20 PM
prerunner's Avatar
prerunner
Default Kore leveling kit update.......
So far i love it!!!!! The ride is a night and day difference!!!
I do have some minor rubbing at full steer on the passenger side, nothing on the drivers side. Passenger tire is rubbing the sway bar and the rear stabilizer bar. So i may be looking at new rims in the near future!!!!!
Took her in today for an oil change and alignment. Alignment was slightly off, but wasn't that bad according to the tech!!!!
I also got the high idle turned on. Should I only use this for warming up the truck?????
They said they couldn't adjust the speedo for my bigger tires. Anything after 05 did not have that feature. I'm hoping Parts&Service reads this and can chime in????
She also gets a lot more attention when sitting still. I think its the silver Bilstein 5100's that gets everyones attention!!!!!
Old May 11, 2008 | 09:27 AM
Bass Hunter's Avatar
Bass Hunter
Default RE: Kore leveling kit update.......
might need an adjustable trac bar to center the axle. If its rubbing one side and not the other the axle is not centered.
Old May 11, 2008 | 10:03 AM
Az2500Cummins08's Avatar
Az2500Cummins08
Is is the right tire that is rubbing?
Old May 11, 2008 | 11:10 AM
prerunner's Avatar
prerunner
Yeah, its the right tire that is rubbing.
Looking at it, it looks centered. I'll be stopping by a shop sometime next week to have them look at it. I need to get some prices for gauges anyways
Old May 11, 2008 | 02:05 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: prerunner
an adjustable tracbar (I have a thurenfab one) will fix that right up... look down the sides and you'll see one side is about .75~1.0" off... split that when you center it and it'll look right & not rub.
Old May 11, 2008 | 04:34 PM
DiEseLjunKy's Avatar
DiEseLjunKy
Yeah it moves your axle off center when you level it. You can get offset bushings for the stock trac bar for about $100 to center it back up. But the extra money for thuren adjustablewould be best if you ever think you might slap ataller lift on.
Old May 11, 2008 | 05:37 PM
Buford445's Avatar
Buford445
Is this common with all leveling kits ? Was thinking abought the Hell Bent, will that take the axtel off center ?
Old May 11, 2008 | 05:53 PM
firemansdodge's Avatar
firemansdodge
Adjustable Trac Bar will not help the rubbing. The backapacing of the stock wheel is 6.25". Any wheels w/ 5.5" & 6" of backspacing and no wider than 9" is the correct wheel w/ a 3" suspension up front on our trucks.
You should just be rubbing the upper control arms and nothing else w/ the stock wheels. It'snot going to hurtnothing other than how much can you tolerate the rubbing noise at almost full lock.
Old May 11, 2008 | 08:17 PM
mytowrig's Avatar
mytowrig
you might want to make your sig smaller before one of the mods decides to yell at you for it...
Old May 11, 2008 | 11:15 PM
prerunner's Avatar
prerunner
Thnx for the warning towrig, but they beat ya to it. Its been deleted until i can get it smaller.
