lowerin egts
i was just curious some of the ways to lower the egts.i have a dodge ram3500 an 03 its got the ho cumins in it.i have a cold air intake bigger injectors a cold air intake and the juice atitude in it and bigger exhaust.i love this web site i have been folowin it for years and i finally have a real truck since my last 2 have been half tons.this site has helped me before and i guess i can use some help again thanks
Well, you've already started with a few of the basics with the intake and exhaust. Just remember that, for now, don't tow any higher than level 2 on that Edge. 1 - the EGT's will skyrocket and 2 - your tranny won't take it for long.
Other than drugs, increasing airflow if is the only way to bring and keep the EGT's in check. Sooooo, what I suggest, in this order and aside from what you've already done.
1 - new intake manifold
2 - new exhaust manifold
3 - new intercooler
The stuff below will require you to stud the heads and get a better (i.e. o-ringed) head gasket.
4 - twins (compound turbos)
5 - water / meth injection
6 - nitrous injection
Obviously, those are increasing expenses / difficulties.
Only things that reduce EGT's are more air or less fuel or the use of drugs.
With my current setup, I hit my boost limiter well before I get close to EGT limits.
3 - new intercooler
what are your EGT's getting to??? if you can nail over 1350 with ease then yea, you need help, but if it takes a bit for you to hit 1200 then your OK.
with what you have done so far the only thing that may help out would be a turbo that flows more air. you dont need any more fuel right now, just more air to go with the fuel to cool things down.
well i guess around 1300 for egts but the lower i can get it the beter right well safer anyways whats a smarty and what type of turbo would u guys recomend?i live in b.c thats in canada guys so it doesnt usualy get to hot but we do alot of campin and wheelin in the interior and sometimes it gets pretty hot and theres some big grade hills so any help would be awesome oh ya u guys have to come up this way im sure u would be impressed thanks again
a smarty is a programmer, http://www.madselectronics.com I have one, and there are many others here that have one. Ty(triton) is probably one of the best examples of what this programmer can do, with a little help from other things as well.
a good turbo is going to depend on what you use the truck mainly for, your best bet may be to talk to the turbo experts at HTT, or industrial injection. they can tell you exactly what you need.
