How much diff fluid...
Old Jun 17, 2008 | 06:17 PM
04QC4X4's Avatar
04QC4X4
Default RE: How much diff fluid...
Thanks guys. If I pull the gasket off and it tears or something should I get a new one from dodge or the auto parts store, or should I make another out of RTV silicon.
Old Jun 18, 2008 | 05:05 AM
JWW's Avatar
JWW
Mine (2006) wasn't stuck or anything. Came off nice and easy. I doubt you will have issues.
Old Jun 18, 2008 | 10:31 PM
savage.basher's Avatar
savage.basher
Yeah, it definitely won't tear or anything. It is like a really hard rubber or something. I don't think my diff covers have any type of fluid level indicator on them?
Old Jun 23, 2008 | 11:14 AM
Ruggedroast's Avatar
Ruggedroast
Yeah I've still got stock covers and there is definitely no indicator on mine.
Old Jun 23, 2008 | 10:54 PM
04QC4X4's Avatar
04QC4X4
Just pull the plug out and you can see the fluid inside. If you stick your finger in you should feel fluid right below the hole.
Old Jul 1, 2008 | 05:43 PM
crpilot212's Avatar
crpilot212
New Member
Check out the application guide from Amsoil. Punch in your truck specs and it will tell you all of your fluid capacities as well as torque specs for all plugs and cover bolts.
http://www.amsoil.com/scripts/runisa...msoiloaf:index
P.S. The differential gaskets are rubber over steel.Don't worry about tearing anything. If you pull all bolts but the top one and loosen it2 turns, the oil will break the gasket loose as it drains and your cover won't fall off and flip gear oil all over the place. Just wipedown the gasket,the gasket surface on the diff and cover, thenthrow it back together at the correct torque, and you'll be fine.
"Tractor" 2005 25004x4QC LB CTD, 6-Spd,S&B Intake, PML rear diff cover,N-Fab 6 steps
