My first deisel has an oil leak
Old Aug 5, 2008 | 11:06 PM
Sled's Avatar
Sled
Junior Member
Default My first deisel has an oil leak
Just got a Ram 2500 CC 6.7 Cummings, had 16K miles (still Bumper to bumper)
has a small but noticeable oil leak from the front bottom of motor.
There is "drips" of oil from above the oil pan. (timing chain cover?). I am pretty sure the leak is NOT the oil pan gasket, as I have drips from above that.
My question, what would be my possible sources of the leak?
oil pan gasket
Timing chain cover
Front main seal????
Crank seal?? (same as front main seal?)
what else?
do any of these require the engine to be removed from truck?
Thanks for your input.
Sled (from Aces High)
Old Aug 5, 2008 | 11:58 PM
Mayfair's Avatar
Mayfair
Normal
More than likely it is from the blow by hose located near the timing chain cover. Follow the drips. The probably come from a hose. Some guy's contain the drips in a soda bottle or something similar and dump it at every oil change.
Old Aug 6, 2008 | 12:06 AM
Mayfair's Avatar
Mayfair
Here's one way to catch the oil
Attached Thumbnails My first deisel has an oil leak-oil-catch-can-31023294670.jpg   My first deisel has an oil leak-oil-catch-can-31023294611.jpg
Old Aug 6, 2008 | 12:23 AM
Sled's Avatar
Sled
Junior Member
Thanks Mayfair.
Is this the case for a 2007 6.7? Or are you talking about older models of Cummins?
Hard to believe this is the normal design. An intentional Oil Leak? On a new Truck????
Well, I did say my first Cummins Truck.
Old Aug 6, 2008 | 01:20 AM
Mayfair's Avatar
Mayfair
Is it a leak, or a drip? If you're seeing puddles then it's not normal. If it's spotting the driveway, it's normal on the 5.9's. I can't imagine that they were fixed on the 6.7's but I can't say for sure.
Old Aug 6, 2008 | 01:26 AM
Sled's Avatar
Sled
Junior Member
Yeah it is a drip.
thanx for your help
Old Aug 6, 2008 | 05:30 PM
Sled's Avatar
Sled
Junior Member
I am now being told that there should be NO oils leaks from this engine.
The "Blow by tube" on the 5.9's is not on the 6.7's.
If true then this is a problem that is not normal.
Can anyone confirm this?
TY
Sled
Old Aug 6, 2008 | 07:02 PM
NickBeek's Avatar
NickBeek
Can't speak from experience on the 6.7, but the crank case vent tube on the 5.9 that Mayfair is referring to comes off the drivers side of the valve cover about 2/3 of the way back on the engine and turns toward the ground. It ends near the top of the oil pan on the drivers side. If you look under there and it still on the 6.7 you should be able to find it pretty easy.
Have you checked your oil lately? If not I suggest that you keep an eye on it. I have seen several posts with high fuel content in the oil in the 6.7 motors. If your oil is over full or the level is rising over a period of time, you should have it checked out ASAP.
Old Aug 7, 2008 | 02:05 AM
cracker's Avatar
cracker
I hope you have the mx records for a used 16k mile truck. If not the dealer should. Maybe had a problem that the previous owner got tired of dealing with. I would check that vent tube. If not installed or not coming from that, check oil level, if high sample for you own peace of mind to make sure no fuel in oil. Let the dealer deal with it under the warranty.
Old Dec 2, 2010 | 01:41 PM
shortyR6's Avatar
shortyR6
where is the vent tube? i have the same type of leak on my 03. it is just behind the bottom pulley. i figured i needed a seal or gasket as well, just have not gotten in there to see where its originating from.
