boost question 41 psi
Old Oct 17, 2008 | 04:31 PM
jamieamber@embarqmail.com's Avatar
Default boost question 41 psi
i have a 2005 2500 cummins
edge attitude chip aem intake straight pipe from the cat out
on stock i hit 39 psi
all other levels i hit 41pst
is this ok safe any input helps
also my filter minder is always reading clean the filter its a synthaflo
and was just cleaned maybe i also need cleaning tips the instructions were not in the box '
thanks for your help Jamie
Old Oct 17, 2008 | 05:22 PM
Bass Hunter's Avatar
Bass Hunter
Around 40 psi of boost is fine for a stock turbo the problem is above 35 you are really just blowing alot of hot air, the efficency goes way down. I have my edge set to limit boost to 35 psi. The settings are easy to change on the attitude monitor I would suggest you limit the boost. I doubt you will see any change in performance. The filter minder is always showing that you need cleaning because obviously you romp on it and the turbo is sucking it in. You are moving huge quanities of air when you stomp on these things. but boy is it fun as hell.
Old Oct 17, 2008 | 08:18 PM
lxman1's Avatar
lxman1
Site Moderator
You might try here.https://dodgeforum.com/forum/forumdisplay.php?f=88
Old Oct 18, 2008 | 11:52 AM
Default boost
thanks for the info
i set the back down at 36 and i still am hitting 41 42 psi the back down is working what should i det the egr alarm and limmit at its 1375 now
any recomendation on low boost fueling is 5 for power 1 for milage
Old Oct 18, 2008 | 03:13 PM
Bass Hunter
It depends where you put the egt probe. If it is pre turbo you can hit 1300 for a moment and its fine 1200 is totally safe. If the probe is after turbo it should be between 1000 and 1100. And yes five is for power and responsiveness and 1 is for fuel econemy.
Old Oct 18, 2008 | 05:46 PM
Bass Hunter
Another thing is if you go around above level 3 alot and are getting on it alot you are going to need to do transmission upgrades.
Old Oct 19, 2008 | 11:55 AM
Default upgrades
i have a 6speed tranny
do i need to wory about the clutch
i only romp on it for fun once in a wile and no speed shifting
Old Oct 19, 2008 | 11:57 AM
Default exhaust probe
egr reads from my exhaust manifold on top of the collecter
Old Oct 19, 2008 | 02:57 PM
Bass Hunter
It can overpower the clutch just go easy on it when shifting. Besides a hi performance clutch will only set you back a couple grand a hi performance auto is between 4-7 grand. If your egt probe is in the exhaust manifold thats pre turbo so your good for short bursts at 1300 degrees 1200 is no problem at all.
Old Oct 21, 2008 | 10:05 AM
nomolos1's Avatar
nomolos1
Go to Southbend Clutches, for a good, and en-expensive clutch that will hold some power.
