Normal Boost for stock 5.9l
Old Nov 16, 2008 | 05:02 PM
bloomer89's Avatar
bloomer89
Default Normal Boost for stock 5.9l
Quick question here, what is the normal boost at WOT on a stock 5.9L 24v? The highest mine ever gets is 18 psi.
Old Nov 16, 2008 | 05:20 PM
04QC4X4's Avatar
04QC4X4
I think that is a little low for a 24v 2nd gen. I have a 3rd gen and it will hit 38 psi stock. I think the 2nd gen 24v should hit the low 20's, but I'm not 100% sure.
Old Nov 16, 2008 | 06:40 PM
Big_B's Avatar
Big_B
On a stock seconde gen should be upper 20's low 30's I thought. But maybe I'm wrong.
Old Nov 16, 2008 | 08:32 PM
YAMAHARIDER5's Avatar
YAMAHARIDER5
max boost pressure for 24v stock is 23 psi give or take a few psi you will never see close to 30 psi unless you pinch of the waste gate hose or put a diffrent waste gate on the stock hx35 turbo. At wot that is low check all you cac hoses to see if they have a hole or have slipped off. If that doesnt fix it could be the map sensor or possible the waste gate actuator is wearing out.
Old Nov 17, 2008 | 09:53 AM
9612valve's Avatar
9612valve
my 1999 24 valve builds 19psi and it will run like a scolded dog but still gets 26mpg
Old Nov 19, 2008 | 07:59 PM
bloomer89's Avatar
bloomer89
Default Answer to questions
Thanks guys, thats great info.
Could it possibly be a leak/hole in the intercooler boots?
I haven't had time to get in and look yet at the clamps etc.
Old Nov 19, 2008 | 09:12 PM
Big_B's Avatar
Big_B
I stand corrected... I shall go read more before i open my big mouth lol.
Old Nov 21, 2008 | 11:39 PM
DodgeAdvisor's Avatar
DodgeAdvisor
The turbocharger boost pressure specs are between 110 - 138 kpa (16 - 20 psi.).
