Best deal on Pro Comps?
i would add that the original pro comps had a bad rap with balancing issues which is what I heard. when I got mine it was a package deal used... $1000 bux + my stockers for the moto metal 951's & the xtreme at's... bought them used, the guy had the receipt that showed me they were on the truck only 2 weeks. currently they have approx 94~95k on them, they do look worn however they are still not down to the wear bars. I have bad upper ball joints which is causing a vibration at 63~70 mph... past 70~75 and it smooths out. there is so much play in the BJ's that you can do the bearing test on it (12/6 oclock & check for movement) and you can feel the bj moving.
If I can get my *** in gear and get them swapped, I should be able to make the 100k (or more). That would be another 1st for me & my rides... (did 700 miles on a tank 1x).
