Squeaky belt on engine cut-off
Old 08-16-2009, 03:35 PM
AU4x4's Avatar
AU4x4
AU4x4 is offline
Default Squeaky belt on engine cut-off
Hey all. I just bought an 04 5.9 cummins and just wondering if anyone knows why the belt squeaks when I cut the engine off. Its just a small squeak but somewhat annoying. Don't figure this to be any big issue or problem just one of those things I'm hoping has an easy fix. Any suggestions for fixing this or any reasoning as to why this is happening would be appreciated. I've tried a belt dressing spray but didn't seem to make a difference. As far as I can see the belts are in good shape too. Any input appreciated.Thanks.
Old 08-16-2009, 04:41 PM
srountreeoo7's Avatar
srountreeoo7
srountreeoo7 is offline
This is normal. Mine does it
Old 08-16-2009, 05:26 PM
Grr287's Avatar
Grr287
Grr287 is offline
yup...normal. there is a thread on here on how to fix it. i think u get a special belt or something. just search for it.
Old 08-17-2009, 12:05 AM
AU4x4's Avatar
AU4x4
AU4x4 is offline
tried searching for it....didn't find anything. do you have a link ? or does anyone know a fix for this ? let me know. thanks.
Old 08-17-2009, 08:34 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
normal, dont worry about it...
Old 08-17-2009, 08:40 PM
racer9's Avatar
racer9
racer9 is offline
GoodYear Gatorback belt will cure it!
Old 08-17-2009, 11:26 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
Old 08-22-2009, 12:07 AM
pizzo's Avatar
pizzo
pizzo is offline
Its the belt and tensioner. Has the belt fell off yet? To cure this go to CUMMINS dealer and buy a belt @ $23.42 and tensioner @ $61.74 and keep a 1/2 inch ratchet and a 13mm 3/8 short socket with ratchet in your truck so when it flys off you don't have to get a tow anywhere.
I bought 2 of each one to put on and the other set to keep in truck with me so when its breaks I can fix it myself.
Old 08-22-2009, 12:09 AM
Ben D.'s Avatar
Ben D.
Ben D. is offline
totally normal. the CTD runs on a very high compression which causes the motor to slow down fast upon shut off so fast that the deceleration can cause a squeak from the belt as the main crank pulley slows to a stop but everything else is moving. totally normal for the motor.
Old 08-22-2009, 06:47 PM
rabbler's Avatar
rabbler
rabbler is offline
You can get a kit from the dealer to add a one way clutch to the alternator.
this will stop the belt squawk.
Part #05183490AA
Might smooth out your engine at idle too.
Many newer vehicles have this style clutch on the alternator to smooth out the engine.
They save wear and tear on the tensioner too.
Quick Reply: Squeaky belt on engine cut-off
