Which Exhaust?
i have mbrp 5inch works great looks good most have the pipe right out the back rt side behind the rear tires I own a boats and wanted it facing down keep that soot off my babies. you can get stacks too but if you roll coal and tow something its not a good idea plus you have to cut up your bed.
heard good things about magnaflow also check are vendor sites in particular
www.doghousediesel.com they have it all just tell them Pizzo sent you from Dodge forums
When I have been looking at some of the systems I have noticed that they sell a muffler delete pipe. Does that just pretty much straight pipe your exhaust or is there some sort of guts in it that does a certain job? I live in Utah and if the vehicle came with a cat then it needs to remain that way but I'm not sure what my dodge has? I don't think it has a cat I think it just has a 3 1/2" exhaust to a muffler and out the tail pipe from there?
Wanna know a little secret about most of the exhausts?.......they're mostly the same, with the exception of the muffer design.
There's only so many ways to make a round pipe, if ya know what I mean.
Now, as far as picking the one that is right for you, ARE YOU MARRIED?....and does your wife ride in the truck? Seems stupid, but it'll cause you some heartache.
Here's what you're looking at as far as sound levels and drone in the cab, from quietest to loudest.
Diamond Eye
HushPower
Magnaflow
MBRP
Silverline
Strait Pipe
I run a 5" Magnaflow Dual setup in mine and I'm very happy with it. I hear more turbo than anything else......then again, 2 turbos make a little noise.
Your '04 will only have a cat if it was a Cali model. Look up by the tranny cross member and you'll see it if it's there.
A muffler delete pipe is just that. It's just a pre-formed section of pipe that gets rid of the muffler, making it a straight pipe system.
Diamond Eye
HushPower
Magnaflow
MBRP
Silverline
Strait Pipe
It does okay.....
Let me know which system you're looking for and I'll throw some numbers at ya.
I'm assuming you just want 4", side exit or duals, with or w/o muffler?
You're in UT, so I'm assuming you'll at least want 409 stainless and not the aluminized system?
Trending Topics
