Rough Idleing?
Old Nov 30, 2009 | 03:54 PM
ecwrestoration@yahoo.com's Avatar
Default Rough Idleing?
05 QC, short bed 4.10 gears, 179,000 miles. Was wondering if a bad lift pump (tank) would cause a rough idle problem? If the lift pump was bad would the cp3 injector pump pull fuel without the tank pump helping? Was at the auto parts place and the counter guy came outside to hear my idle and said it was (lobeing)? Starving for fuel? Starts fine, runs good except for idleing and on the highway (50 or 60mph, if you hold the pedal still, she tends to buck)? Only code showing are p2609, but that would not effect my situation? Only mods are 5" exhaust, air cleaner, trans rebuild.
Old Nov 30, 2009 | 04:54 PM
Coal Train's Avatar
Coal Train
Sounds more like a rail pressure issue.
Most likely it's the FCA on the CP3 crapping out on ya.
I'm assuming you've done the common stuff, like change the fuel filter?
Also, that code for the abnormal voltage drop at the grid heater starts showing when the batteries are getting weak. Are they the original batteries?
That could be part of the problem.
Old Nov 30, 2009 | 05:56 PM
Filter is ok and batts. are origonal!
Old Nov 30, 2009 | 05:58 PM
can i get a new FCA from dealer, auto part place?
Old Nov 30, 2009 | 06:02 PM
2005RAM2500's Avatar
2005RAM2500
How much pressure should be at the stock fuel filter? and rail?
Old Nov 30, 2009 | 06:17 PM
Have not checked the fuel pressure.
Old Nov 30, 2009 | 06:24 PM
Coal Train's Avatar
Coal Train
Fuel pressure and rail pressure are 2 different animals.
You should be seeing 13 - 15 psi of fuel pressure at the CP3 inlet.
You can see any where from 6400 - 20000+ psi of rail pressure.
At idle you should be seeing between 6400 - 6800 psi of rail pressure in park or neutral.
Have those batteries tested, I bet that's part of the problem. If they're weak and th grid heater is kicking on, the rest of your truck is sucking for power.
If you need the FCA, the best place to get it is a Cummins dealer or a Bosch service center.
Old Nov 30, 2009 | 07:28 PM
Tried taking the fca out but can't get the T25 torque bolts to move, any suggestions?
Old Nov 30, 2009 | 07:31 PM
Coal Train's Avatar
Coal Train
Tap the bolt lightly with a SMALL hammer.
They have a bit of blue loc-tite on them.
Once you have the FCA out, shake it back and forth, you should hear it click.
If you don't hear it click, it's sticking and that will cause the erratic idle.
I'm still betting on the batteries.
Old Nov 30, 2009 | 07:33 PM
Went too advance auto parts & they don't carry fca's for the cp3. Guess its a dealer item.
