Crankshaft Sensor Help
Old Dec 28, 2009 | 01:19 AM
MossyOakGirl's Avatar
MossyOakGirl
Exclamation Crankshaft Sensor Help
I've been looking all over and I can't seem to find the exact answer to my question. We have a 2000 2500 Cummins Ram. The CPS sensor is going out and we need to replace it. If anyone knows a good place to find directions on how to do it or has any helpful hints it would be greatly appriciated. TIA
Old Dec 28, 2009 | 03:14 AM
dodgetrucker75's Avatar
dodgetrucker75
what year is your truck, most are very easy to do...
Old Dec 28, 2009 | 08:36 AM
Cartalk2's Avatar
Cartalk2
Just wondered, what are the indications the CPS needs to be changed??
Thanks in advance.
Old Dec 28, 2009 | 09:53 AM
Coal Train's Avatar
Coal Train
The CPS is located with on the driver side of the crank pulley. Looking at it from the front of the truck, it's in the 5 o'clock position.
It's real easy, it's only one allen head bolt that holds it in. Loosen the bolt, pull it out, put the new one in.
This is what you're looking for. Items 1,2 & 3 are the sensor, o-ring and bolt. Right where the sensor goes in is directly behind the crank pulley. Disregard that other sensor showing, that's the MAP sensor.....
The cam position sensor is the one that's a pain in the butt. It's located directly behind the VP44 or CP3.
The cam and crank position sensors are the same part number and are interchangeable. If you suspect one is going bad, you can swap them and see if it effects the other system. The crank sensor doesn't have much effect other than the tach. Now the cam position sensor will really screw things up. The ECM doesn't know when to fire the injectors, it'll smoke like crazy, it may not run at all.
Cartalk, a good indication that the crank position sensor is going out is erratic tach readings.
Old Dec 28, 2009 | 10:34 PM
MossyOakGirl
Thanks for all the help. We think it's the Crankshaft because of the codes that are coming up. It randomly doesnt like to start but if you go back 20 min. to an hour later it fires right up also the Tach randomly takes a dump. The truck will be driving down the road just fine and the Tach will just drop to zero. It also seems like the alternator will quit charging sometimes as well. If you think this sounds like something else let me know.
Old Dec 28, 2009 | 10:44 PM
Coal Train's Avatar
Coal Train
Check the wiring harness that runs up the passenger side of the engine block.
You have the alternator, AC compressor, intake temp, and a host of other sensors that run in that bundle and it has a tendency to rub through and ground out.
Easiest way to get at it is to remove the front passenger tire and fender liner and then you''l be able to get at the harness easier.
Unplug EVERYTHING and inspect the harness for wear. When you Reconnect everything, re-route it so it's not in any wear spots.
Old Dec 29, 2009 | 02:12 PM
MossyOakGirl
Thank you, We'll give it a shot and let you know what happens.
Old Dec 29, 2009 | 05:05 PM
Cartalk2's Avatar
Cartalk2
Coal Train -- Thank you for info.
Old Dec 29, 2009 | 07:36 PM
Coal Train's Avatar
Coal Train
No problem.
Old Nov 20, 2019 | 01:52 PM
barobertosjuior2772's Avatar
barobertosjuior2772
New Member
Default π‘πΎπ·π΄π°ρŽ πΊπΎπΏπΈπΈ ρπ°πΉρ‚πΎπ² πΎρ‚ 500 ρ€ρƒπ±π»π΅πΉ π·π° π»π΅π½π΄πΈπ½π³
Π—Π΄Π΅ΡΡŒ Π²Ρ‹ ΠΌΠΎΠΆΠ΅Ρ‚Π΅ Π·Π°ΠΊΠ°Π·Π°Ρ‚ΡŒ копию любого сайта ΠΏΠΎΠ΄ ΠΊΠ»ΡŽΡ‡, Π½Π΅Π΄ΠΎΡ€ΠΎΠ³ΠΎ ΠΈ качСствСнно, ΠΏΡ€ΠΈ этом Π½Π΅ тратя своС врСмя Π½Π° Ρ€Π°Π·Π»ΠΈΡ‡Π½Ρ‹Π΅ ΠΏΡ€ΠΎΠ³Ρ€Π°ΠΌΠΌΡ‹ ΠΈ фриланс-сСрвисы.
ΠšΠ»ΠΎΠ½ΠΈΡ€ΠΎΠ²Π°Π½ΠΈΡŽ ΠΏΠΎΠ΄Π»Π΅ΠΆΠ°Ρ‚ сайты ΠΊΠ°ΠΊ Π½Π° конструкторах, Ρ‚Π°ΠΊ ΠΈ Π½Π° Π΄Π²ΠΈΠΆΠΊΠ°Ρ…:
- Tilda (Вильда)
- Wix (Викс)
- Joomla (Π”ΠΆΡƒΠΌΠ»Π°)
- Wordpress (ВордпрСсс)
- Bitrix (Битрикс)
ΠΈ Ρ‚.Π΄.
Ρ‚Π΅Π»Π΅Ρ„ΠΎΠ½ 8-996-725-20-75 Π·Π²ΠΎΠ½ΠΈΡ‚Π΅ ΠΏΠΈΡˆΠΈΡ‚Π΅ viber watsapp
ΠšΠΎΠΏΠΈΡ€ΡƒΡŽΡ‚ΡΡ Π½Π΅ Ρ‚ΠΎΠ»ΡŒΠΊΠΎ одностраничныС сайты Π½Π° ΠΏΠΎΠ΄ΠΎΠ±ΠΈΠΈ Landing Page, Π½ΠΎ ΠΈ многостраничныС. БоздаСтся полная копия сайта ΠΈ Π½Π°ΡΡ‚Ρ€Π°ΠΈΠ²Π°ΡŽΡ‚ΡΡ Ρ„ΠΎΡ€ΠΌΡ‹ для ΠΎΡ‚ΠΏΡ€Π°Π²ΠΊΠΈ заявок ΠΈ сообщСний. ΠšΡ€ΠΎΠΌΠ΅ Ρ‚ΠΎΠ³ΠΎ, ΠΏΠΎΠ΄ΠΊΠ»ΡŽΡ‡Π°Π΅Ρ‚ΡΡ Π°Π΄ΠΌΠΈΠ½ΠΊΠ° (Π°Π΄ΠΌΠΈΠ½ панСль), ΠΏΠΎΠ·Π²ΠΎΠ»ΡΡŽΡ‰Π°Ρ Ρ€Π΅Π΄Π°ΠΊΡ‚ΠΈΡ€ΠΎΠ²Π°Ρ‚ΡŒ ΠΊΠΎΠ΄ сайта, ΠΈΠ·ΠΌΠ΅Π½ΡΡ‚ΡŒ тСкст, Π·Π°Π³Ρ€ΡƒΠΆΠ°Ρ‚ΡŒ изобраТСния ΠΈ Π΄ΠΎΠΊΡƒΠΌΠ΅Π½Ρ‚Ρ‹.
Π—Π΄Π΅ΡΡŒ Π²Ρ‹ ΠΏΠΎΠ»ΡƒΡ‡ΠΈΡ‚Π΅ вСсь комплСкс услуг ΠΏΠΎ ΠΊΠΎΠΏΠΈΡ€ΠΎΠ²Π°Π½ΠΈΡŽ, Ρ€Π°Π·Ρ€Π°Π±ΠΎΡ‚ΠΊΠ΅ ΠΈ ΠΏΡ€ΠΎΠ΄Π²ΠΈΠΆΠ΅Π½ΠΈΡŽ сайта Π² ЯндСксС ΠΈ Google.
Π₯ΠΎΡ‚ΠΈΡ‚Π΅ ΡƒΠ·Π½Π°Ρ‚ΡŒ сколько стоит ΡΠ΄Π΅Π»Π°Ρ‚ΡŒ копию сайта?
Π½Π°ΠΏΠΈΡˆΠΈΡ‚Π΅ Π½Π°ΠΌ
