tranny gremlin
tranny gremlin
My 98 auto trans has a very strange issue. I dont have anyway to explain the problem except this, when cruising between 40mph and 52mph the transmission feels like it cant decide to be in or out of overdrive. Thats the best way to describe the problem. It does it with or without a load. Please help! and ill try to give you the best descriptions as possible
Clean all of your grounds. Battery, frame, block, transmission, electrical connectors. What you are describing is a pretty common complaint. Many times it can be corrected by cleaning the grounds. The electrical signals are kinda sensitive on those transmissions. If cleaning doesn't help, post back, we'll help you out
If it is the TPS one option is this:
http://www.dieseltruckresource.com/d....html?t=142641
Not sure what years it will work on, I know that it will cover my 96 w/47re
Floyd
Floyd
