Need injector pump ....$$$ ouch!
Old Dec 30, 2010 | 06:55 PM
CoreyHendricks's Avatar
CoreyHendricks
Default Need injector pump ....$$$ ouch!
Alright so im driving my bosses 99 24v dually and it dies while making a turn ....i thought maybe it ran out of fuel ...2hrs later on the side of the road still cant get it started finally i have a buddy who works at the dodge dealership come out and run diagnostics injector pump throws three different codes...with out a doubt he says injector pump needs to be replaced... !$2k! so we ended up towing it home and parking it till we can get it fixed ....after a very minimal search of the internets i have come to the conclusion that this year model injection pump is a piece of crap ....and expensive....true or false? If at all possible i would like to find a fairly cheap injector pump... is that possible? if not since im going to have to spend some money is there a better injection pump for this year model than the VP44? last question ...is this something i can replace myself or there any little tricks or tools i need to know about? ......sry for the bombardment of questions ....
Old Dec 30, 2010 | 07:21 PM
brettj2408's Avatar
brettj2408
run a volume test on your lift pump to see if your lift pump is putting out enough pressure to your injection pump..
low lift pump pressure will cause injection pump failure
Old Dec 30, 2010 | 07:24 PM
stodg73's Avatar
stodg73
This is the only pump for the 98.5 -2002 models, unless you want to P-Pump it, even more $$$$$. Yes, the VP-44 is expensive and you can no longer get new ones, they are all remanufactured. You also need to get an aftermarket lift pump on order to supply the VP better than the stock unit. The stock unit probably failed and took the VP with it.
Here is a link for an injector pump: http://www.dieselautopower.com/
If you are mechanically inclined, you should be able to do it in about 2 days.
Old Dec 30, 2010 | 11:39 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
Originally Posted by stodg73
2 days.
You must be drinking a lot of beer!!!
Most people say 4-6 hours to replace the injector pump. It's not so much the VP-44 that is a POS, but the lift pump that is a POS. Lift pump goes= dead VP-44 in as little as a couple of minutes.
This seems to be one of the best places to get a reman pump:
http://www.industrialinjection.com/id75.html
Old Dec 31, 2010 | 09:41 AM
starscream's Avatar
starscream
Default fuel pump
hi there someone told me that these 24,s were also fitted with the inline pump, they said it was a one tonne,
Old Dec 31, 2010 | 11:05 AM
stodg73's Avatar
stodg73
All 24 v's from 98.5 to '02 have an inline lift pump on the block next to/behind the fuel filter. This fails and takes the VP with it.
Old Dec 31, 2010 | 03:11 PM
starscream's Avatar
starscream
I ment to say 24v can be fitted with the more robust inline injection pump from the 12v.
Old Jan 4, 2011 | 08:08 PM
CoreyHendricks
Thanks guys that's why i needed to know we had a new injector pump put on now im shopping around for a better lift pump an suggestion?
Old Jan 6, 2011 | 03:26 PM
a4x4high's Avatar
a4x4high
What are you guys running for aftermarket lift pumps?The 01 I just bought is using the air dog system thats supposed to keep air out of the fuel and filter it also.Is this system any good or should I consider something else?
Old Jan 6, 2011 | 04:09 PM
stodg73's Avatar
stodg73
As long as you have a fuel pressure gauge and keep it above 10 psi at wide open throttle, that airdog will be fine.
