any tips for fuel plate install?
Old Feb 15, 2011 | 02:14 PM
01ramcummins's Avatar
01ramcummins
Default any tips for fuel plate install?
Does anyone have any tips or ntk recomendations for installing this fuel plate? The truck is a 96 2500 with really nothing done to it. Im looking for ideas on best placement or whatever else. How to calibrate it or whatever needs to be done. Best way to do it right the firat time hopefully sort of thing. Any help is appreciated. Thanks everyone
Old Feb 15, 2011 | 06:04 PM
dodgetrucker75's Avatar
dodgetrucker75
i hope you didnt spend hundreds of dollars on one of thoes rediculas things.... they arnt to bad to change, they always tell you to pull the intake horn, i never do, the biggest pain is removing the break off screw from the afc housing, my favorite way is to use a small chisel and catch an edge of the head to break it loose then they normally come out by hand, then remove the other 3 screws and the boost line and your there, as far as placement, foward=more fuel/power, back=less fuel/power, its up to you where you want it, and what your trans or clutch can handel
Old Feb 16, 2011 | 08:21 AM
01ramcummins
Well. The trans is a piece of crap. Has been sense the beginning. But yea. So there is no speciall formula to make sure it runs right? Right? I was told awhile back that it takes a few times to dial it in correctly. So that was my biggest concern was getting it to run proper. Thanks
Old Feb 16, 2011 | 01:17 PM
dodgetrucker75
it doesnt affect how it runs at all, it just limits the full fuel flow, if you are just looking for more power, slide the plate and the afc full forward, also backing the afc spring tention off, will help out the bottom end some
Old Feb 16, 2011 | 07:41 PM
01ramcummins
Thanks man. Very much. Helps alot. Im always lookin for help on the truck if i cant figure it out. I do have another quest. Tho. Is there any way to make the turbo any louder? I already took the silencer out but i want it a little louder. And i dont have the money for a bigger turbo. Lol
Old Feb 17, 2011 | 01:03 PM
dodgetrucker75
a cold air intake with a big cone filter, they make a lot of noise
Old Feb 17, 2011 | 04:00 PM
01ramcummins
Well. Ive put a big honkin air filter on there and didnt make a difference. Is there a certain thing that the cold air does that just a massive airfilter doesnt? I dont want the whistle the only thing you hear like the fords do. I just wanna be able to hear the whistle. Lol. Thanks again. I think someone said somethin bout drillin a small hole in a elbow that comes off the turbo or somethin?
Old Feb 17, 2011 | 04:12 PM
dodgetrucker75
is it a paper filter you have on there?
Old Feb 17, 2011 | 07:06 PM
01ramcummins
Yes sir. Who makes a huhw filter thats not paper. And website please and how much. Haha
Old Feb 18, 2011 | 01:16 PM
dodgetrucker75
afe stg.2 is what i run, thoes big paper filters do good on air flow, but they are a giant muffler when it comes to turbo noise
