2007 ecm/pcm codes
Old Oct 23, 2011 | 01:35 PM
paintedhorse's Avatar
paintedhorse
Default 2007 ecm/pcm codes
I need help! My 2007 dodge 2500 4 wheel drive with 5.9 cummins is showing a code. I went ot autozone had the code read and it come out that the ecm/pcm intermitten power input. What does this mean and how do I fix this?
Does this mean I need a new computer for the truck?
Old Oct 23, 2011 | 02:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the code yourself with the key trick https://dodgeforum.com/forum/2nd-gen...code-list.html. Then post the code that comes up in the 3rd gen ram section.
Old Oct 24, 2011 | 09:07 AM
DodgeCares's Avatar
DodgeCares
Painted,
Please post code and I can look it up for you.
Old Oct 30, 2011 | 04:37 PM
paintedhorse
I went to autozone and the code they gave me was p2509. I called dodge dealer and they said it was my battery or battery connection. I have checked my batterys and every wire that i can find. This made no differience. Two days later the light went off. The truck runs great but has no fuel milage. This has been 3 days no light , today after sitting all night, I started the truck, when you turn of the key all is well, when it gets to the start postion it sounds like a electric fuel pump rattling as it trys to start, truck starts runs great engin light is on. and bad fuel milage. I also done the key trick, The engin light flashed 10 times. thats all it did not give any info.
Old Oct 31, 2011 | 01:17 PM
DodgeCares's Avatar
DodgeCares
Painted,
Found this TSB on your issue. Perhaps it will help.
NUMBER: 18-001-07
GROUP: Vehicle Performance
DATE: January 06, 2007
SUBJECT:
Flash: Check Gauges Lamp Illuminates For Alternator Charging With DTC P2502, P2503,
or P2509
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (Cummins PCM) with new software.
MODELS:
2006 - 2007 (DH/D1) Ram Truck (2500 / 3500)
NOTE: This bulletin applies to vehicles equipped with a 5.9L engine (sales code
ETH) built on or before November 29, 2006 (MDH 1129XX).
SYMPTOM/CONDITION:
The customer may experience the illumination of the “Check Gauges” lamp on the
instrument panel cluster. Inspection of the gauges may reveal that the battery charging
gauge may read in the 11 volt range rather than in the 14 volt range. There may not be a
Check Engine / Malfunction Indicator Lamp (MIL) illumination.
Further diagnosis may reveal the following Diagnostic Trouble Codes (DTC's) have been
set:
P2502 - Charging System Error - Diesel
P2503 - Charging System Output Low - Diesel
P2509 - Powerdown Data Lost Error - Diesel
DIAGNOSIS:
Using a Scan Tool (StarSCAN®) with the appropriate Diagnostic Procedures available in
TechCONNECT, verify all engine systems are functioning as designed. If DTCs are
present record them on the repair order and repair as necessary before proceeding further
with this bulletin.
If the vehicle operator describes or experiences the Symptom/Condition, perform the
Repair Procedure.
Old Oct 31, 2011 | 01:42 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
This sounds like a 3rd Gen/Diesel related question.
Old Nov 1, 2011 | 06:20 PM
paintedhorse
I have tested batterys and connections. This morning I went to start the truck, turned the key the starter hit did not turn the engin, all lights and bussers went off. should I post in third generation?
Old Nov 1, 2011 | 08:04 PM
Or the diesel section......
Old Nov 6, 2011 | 11:39 AM
paintedhorse
Hey guys changed both batterys and all is well. thank you for your help.
