roling smoke
Old Nov 4, 2011 | 06:11 PM
dodge626's Avatar
dodge626
Default roling smoke
hey guys i was reading a post on here a while back and the guy did a bunch of things to his truck i believe it was a bigger turbo, head studs, exhaust manifold, nozzles and lift pump so my question is which one of those would make him roll alot of smoke? he had videos on his post and it looked like anytime he got on the throttle lots of smoke was coming out even when he was in town where the speed limit is like 30. thanks guys
Old Nov 4, 2011 | 08:42 PM
horatio102's Avatar
horatio102
ah, douchey. My truck will dump smoke when I turn the fuel up and stand on the throttle, but it's wasted fuel and the reason the government is cracking down on diesels in general.
Old Nov 5, 2011 | 11:53 AM
dodge626's Avatar
dodge626
i know its wasted fuel i was just curious which one of those parts he put on got that to happen because my truck has a tuner and 4 inch straight pipe with the boost turned up and i get little puffs of smoke
Old Nov 5, 2011 | 12:23 PM
horatio102's Avatar
horatio102
Depends on the tune really. I'm not sure on the vp44/24 valve trucks, but the cp3/hpcr trucks it's entirely possible to billow a bunch of smoke with just a tune. If you got a more conservative tune/programmer, you're not going to get as much smoke.
If you've got a vp44 you may need to upgrade the pump if you upgrade your injectors.
Old Nov 5, 2011 | 12:32 PM
dodge626's Avatar
dodge626
my 03 what pump should that have? and its the edge juice with attitude and 4 inch straight pipe i want to do more things to it but not alot of money in my pocket right now so i must wait im just curious about all of this
Old Nov 5, 2011 | 02:21 PM
verdesardog's Avatar
verdesardog
I don't understand....why do you want to waste fuel and pollute the air?
Old Nov 5, 2011 | 06:04 PM
dodge626's Avatar
dodge626
i was just curious which one of those parts helped his truck to do that? didnt say i wanted to do the same
Old Nov 5, 2011 | 10:54 PM
scatpack_69's Avatar
scatpack_69
Nozzles and a larger, laggy turbo can be a smoke show. I put a Silverbullet on my stock truck, other than Smarty TNT and built trans, and it would just douche smoke for over a half mile before the turbo lit. That was mild pedal input to.
My 03 with Smarty TNT won't smoke hardly at all, where the same program on the 07 will blow smoke at will.
Save the smoke for the backroads with your buddies, not in town.
