going backwards
Old Dec 20, 2012 | 12:03 PM
Jigabop's Avatar
Jigabop
bump the timing up on that thing...more timing = less heat.
and if you like the power but you're sick of the heat, ditch that POS hybrid turbo and get something like a super B single. should lower your EGTs quite a bit by reducing the drive pressure on the turbine and having a bigger gate that vents all 6 cylinders instead of just 3 like the hybrid, and a turbine housing that can breathe better.
your hybrid is either a 60/60/12 (if using stock housing) or a 60/60/14 (if you have the cheap chinese knockoff hybrid)
a super b single is a 57/65/14 S300G. borg warners fin design is far more efficient than holsets fin design making the turbo work a lot better.
Old Dec 20, 2012 | 03:30 PM
jmn1960's Avatar
jmn1960
not jap junk, built it out of two holsets,so probally 60/60/12,,trucker,, yes the pump is on the key,,no other adj. made but the turbo,4"downpipe ,and the injectors,, oh well guess ill just live with it and keep an eye out for some stock inj.,, keep an eye on that damn guage,,thanks for the input jigdbop,,but cannot afford a turbo at this time ,,but will keep that in mind,,damn thing runs real well ,,just dont like the EGTS CLIMBING THAT FAST WITHOUT A LOAD,,
thanks guy for the input
mike
Old Dec 20, 2012 | 05:08 PM
Jigabop's Avatar
Jigabop
bump the timing up to around 26* and that should help.
like I said, timing reduces EGT's and it also improves fuel economy..
Old Dec 20, 2012 | 06:17 PM
jmn1960's Avatar
jmn1960
will try that jigabop,,thanks,, mabe i got it to low,,mabe it moved i will look at the marks on the pump this weekend
Old Dec 20, 2012 | 06:31 PM
jmn1960's Avatar
jmn1960
if i remember right that is the 9/16 wrench to get to those three bolts,, right? dont have the timing pins,, how far shuold i move the pump?? off of center mark towards the engine?? it is about 1/8 now so how much futher should i go??
thanks again
Old Dec 20, 2012 | 07:47 PM
dodgetrucker75's Avatar
dodgetrucker75
the nuts use a 13mm wrench for pump mounts, but anything over the center of the slot will be advanced from stock, usuall very colse to center of the slot is stock setting, pull it all the way over (top of pump twards the head) if you desire
Old Dec 20, 2012 | 07:58 PM
jmn1960's Avatar
jmn1960
all the way trucker??? wont that be to much timing?? hard start,, run rough,,stuff like that,,???
Old Dec 20, 2012 | 08:06 PM
Jigabop's Avatar
Jigabop
this thread: http://www.cumminsforum.com/forum/89...y-ve-pump.html
specifically post #5 should help you with adjusting your VE pump.
you can turn timing all the way to the head
then adjust the rest according to what seems to run best for you as far as spool up, smoke, and power.
Old Dec 20, 2012 | 08:12 PM
Jigabop's Avatar
Jigabop
post #25 is also a very good one for learning how to tune the pump
http://www.cumminsforum.com/forum/89...ml#post5282993
has a diagram and he tells you what their terms are for smoke screw and star wheel and what not and how it translates to the diagram.
so timing will help your fuel economy and should help reduce egt's, and raising the star wheel a bit should keep EGT's from jumping too fast as it forces the turbo to build boost before it gives it harder fueling. basically increases spring tension to where it takes more boost to push the fuel pin down to let more fuel through...
so you will still get more power from having the fueling turned up, its just going to delay the fueling till there is boost which should reduce heat and smoke till the turbo catches up enough to be able to clean it up...if after adjustments you still cant clean up the smoke to a light haze and keep EGT's under control, then its time for a bigger turbo...
Old Dec 20, 2012 | 09:35 PM
jmn1960's Avatar
jmn1960
thanks for the info,, good stuff there,, will mess w/it this weekend and see what i can make of her,,, thanks again for your help,,mike
