going backwards
Old Dec 20, 2012 | 09:43 PM
  #21
jmn1960's Avatar
jmn1960
come to think about it i did turn that starwheel down a couple of turns when i changed the pumps,, so mabe that is my problem,, gotta play this weekend,, its cold out so nothing better to do,, so all the way down (clockwise) then about 3 turns back out otta be a good starting point right?
Old Dec 21, 2012 | 10:55 AM
  #22
jmn1960's Avatar
jmn1960
gonna put it to the head,,smoke screw up,(denny t stage 1),gonna put the star wheel all the way down,, then whatcha all think about how many turns up on the star wheel ,,,3,,4,,,3 1/2,,,,???? mabe i can get it alot closer the first time,,,so from what i gather the injectors are really not that far off of stock , so i guess ill just leave them,,thought mabe they sent me some bigger ones by mistake,, but it is probally my f@^cked up tuning,, never had a diesel before,, oh well trial and error.
thanks again for the info threads,,and the heilp from both of ya,,.
mike
Old Dec 21, 2012 | 11:58 AM
  #23
Jigabop's Avatar
Jigabop
go up 3 turns to start, and drive it, see how it does, and if its still hot and smokey, take it up another turn and drive it, see how smokey/responsive it is...and just fine tune it from there...
its a balancing act of responsiveness vs smoke/heat. you want a good balance where you are still peppy and responsive but not dumping tons of smoke and building tons of heat before your turbo can spool. you just gotta find that sweet spot, and I can't tell you where that is going to be, because every truck will be different. even identically modified trucks will have slightly different sweet spots. you just gotta play with it till you find the settings that work best for you.
up 3 turns from bottom is a good start though. up too high will never fuel, down too low will never spool and smoke like a burning tire. its almost like doing air/fuel ratio screw on a carb...don't want too rich or too lean, want it just right (with the exception you actually have to drive it to figure out if its right or not lol...its all load/boost dependent)
Old Dec 21, 2012 | 12:11 PM
  #24
jmn1960's Avatar
jmn1960
do i need to loosing all the inj lines on the back of the pump??? or will that lil movement bother them? i will allready have the bost line off to do the wheel so that one will be ok
Old Dec 21, 2012 | 12:21 PM
  #25
Jigabop's Avatar
Jigabop
shouldn't have to. if you do loosen then, you will have to bleed the lines to get it to start again...
Old Dec 21, 2012 | 03:05 PM
  #26
jmn1960's Avatar
jmn1960
advancing the timing all the way to the head,,, will that cause hard starting conditions when the engine is at operating temp,, like it does on a gas engine???
Old Dec 21, 2012 | 04:46 PM
  #27
dodgetrucker75's Avatar
dodgetrucker75
nope, actually quite opposite, more timing = eaiser and cleaner start ups on diesel, withch is also what your "KSB" (cold start advance) does
as far as the lines go, you dont have too and i have done many of them with out breaking the lines loose, untill i had a delivery valve (where the line connects to the pump) loosen up and start leaking on one of my customers trucks, now i break them loose everytime
Old Dec 21, 2012 | 05:31 PM
  #28
jmn1960's Avatar
jmn1960
ok thanks,,them line are a bitch to get loose and tighten when u dont have the proper tool,, guess i otta invest in some tubing wrenchs again,, min got lifted in the last break-in at the other house
Old Dec 22, 2012 | 02:18 PM
  #29
jmn1960's Avatar
jmn1960
i read that advanceing the timing (all the way to the head) reduces the egt's but raises the cyl temp,,is this true? and how much does it raise it? do i have to be worried about that after i do the timing?or is it not enough to worry about? or should i just do the starwheel and smoke screw? it is at the 1/8" bumo right now,.sorry for all the ???'s but dont want to hurt her,,
thanks mike
Old Dec 22, 2012 | 07:25 PM
  #30
jmn1960's Avatar
jmn1960
thanks ,,Trucker & Jigabop,, advanced the timing,the starwheel was about 1 turn from the bottom,moved it up 3 1/4 turns,, put fuel pin to the top,, hell of alot better,a differnce,,now gotta play with it to find the sweet spot,,but what a differnce it made,,?????? where should i start on the fuel screw??? i read three turns in,, dont know where mine is at yet. but it is running decent ,,u guys rock!! HEY MERRY CHRISTMAS TO ALL ON THIS FORUM
thanks for your help,,Mike
