CTD....Which Oil?
#21
RE: CTD....Which Oil?
ORIGINAL: GlenninTexas
Anyone using a by-pass oil filter setup? Pros? Cons? What would you expect to see your oil change frequency with one?
Regards, Glenn
Regards, Glenn
steved
#25
According to a link that someone posted here, Cummins says not to run synthetic oil until after 20K miles.
As far as change intervail, as per the Cummins website, when you use CI-4 or CH-4 oils (see my post here, post #2), you can go 15,000 miles on an oil change with the Cummins Ram engine. However, if those are not available, you can use CG-4 oils, but, change intervail will be 7,500 miles.
Of course, changing more often that that will not hurt anything.
I heard rumor it is harmful on your engine when you jump to different oil. Is this true or just a rumor?
