wierd liquid
RE: wierd liquid
Funny how things work. I too noticed a puddle, and knew that it wasn't from the breather tube, wrong consistancy. Mine only does it when its cold and then doesn't leak much, so by the time I was looking for a leak the block was dry. Then I see this post, check it this morning (since its cold here) and sure enough there's a trickle from the hose. I'll roll under it tonight and tighten them up. Gotta love this fourm.
RE: wierd liquid
I just had my truck at the dealer for the same problem. i just knew it was tranny fluid, but it turned out to be coolant. There is a black coolant line directly under the exhuast manifold with a foil covered coupling on it with two hose clamps. The clamps just needed tightening.
