DIY Maintenance: 05 & later grease fitting
Old Feb 12, 2007 | 01:51 AM
  #41
Drew's Avatar
Drew
Default RE: Shocking
alright guys, here is a tip that cumminalong has
Otay fellers....
I got a little itch to screw around with the truck today and re-wired my winch power wires and lubed to d-shaft.
Found a 16 gauge grease needle was too big for the hole. 14 gauge needle worked PUUUuuuuurfect.
All I had to do was put a very slight bend (about 15*) and it went right on home.
Also, go from the drivers side in toward the center and you have plenty of clearance. What I mean is lay on your back and rotate the d-shaft so that the grease fitting is at a 45* angle facing down and toward the driver side of the truck. This clears pretty much everything. You'll know the joint if full when grease begins to seep back out the fitting.
Old Feb 27, 2007 | 08:03 AM
  #42
Little Foot's Avatar
Little Foot
is there a specific grease that should be used on this lubrication? I am going to do my first today and will be heading in to napa to purchase fitting gun and lube.
Old Feb 27, 2007 | 11:05 AM
  #43
DBLR's Avatar
DBLR
You need to get NLGI Grade 2 E.P.or equivalent grease. My self I would get a high quality synthetic grease, but not Mobile 1, I tried it and this summer oil ran out of my grease gun and made a mess so I threw it out. As I see it, if it will leak out of my grease gun in a warm garage how well will it hold up in a U joint?
Old Feb 28, 2007 | 03:56 AM
  #44
beachmstr's Avatar
beachmstr
I am assuming they never changed it in the 07 model and that it still has to be done?
Old Feb 28, 2007 | 11:28 AM
  #45
Drew's Avatar
Drew
yup
Old Feb 28, 2007 | 04:48 PM
  #46
MrSlug's Avatar
MrSlug
Hey Drew, can you make this a sticky at the top. I think its worth being up dere.
Old Feb 28, 2007 | 05:47 PM
  #47
Drew's Avatar
Drew
you can find it in the CTD FAQ thread at the top. . .it used to be but things were getting rather crowded.
Old Mar 1, 2007 | 04:20 PM
  #48
dave_thunderroad's Avatar
dave_thunderroad
ok do all 06 trucks have the fitting or not?? i feel like an idiot looking for this thing.....like i said earlier if it does have it,its never been greased and has 30,000 miles
Old Mar 1, 2007 | 04:42 PM
  #49
Drew's Avatar
Drew
05's, 06's and 07's have this fitting
Old Mar 3, 2007 | 06:51 PM
  #50
DBLR's Avatar
DBLR
I just found out today that this grease fitting is not for the U-joint as they are sealed closed[:'(] What I did read in my 2006 owners manual on page 386 is that this grease fitting is for the front drive shaft, so I will assume they mean the grease is for the drive shaft spline[&o]
