DIY Maintenance: 05 & later grease fitting
Old Jun 14, 2006 | 07:33 PM
Drew's Avatar
Drew
Default DIY Maintenance: 05 & later grease fitting
as many of you have noticed while the hood is up there is a sticker pointing at the front drive shaft about a grease point. this only applies to the 05 and on 4x4's.
the Double Cardan joint has a needle point grease fitting that needs to be lubed every 4K miles and hopefully this will help ya'll out.
the first pic is the fitting itself, the second is the gun fitting needed to grease the point.
[img]local://upfiles/7365/AB1DF7C58B724003A8338F46388A9A1E.jpg[/img]
holy crap that pic is huge. . .sorry, I'll try and resize it tonight
Old Jun 15, 2006 | 04:28 PM
dieselram's Avatar
dieselram
Default RE: DIY Maintenance: 05 & later grease fitting
Now is this an 05 item or a 600 series motor item?
Old Jun 15, 2006 | 05:39 PM
Drew's Avatar
Drew
05 and later trucks is what this applies to. 04's and earlier do not have this joint.
Old Jun 20, 2006 | 05:05 PM
Deleted User's Avatar
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Jun 20, 2006 | 08:17 PM
DBLR's Avatar
DBLR
Drew,
Thanks a million as I have been told twice now while having the oil changed that this grease fitting was not there. Also the part number for the NAPA needlepoint adapter was a big help to make sure I was buying the correct one
Charles
Old Jun 20, 2006 | 10:36 PM
cj5nutz's Avatar
cj5nutz
Junior Member
Thats every 4 thousand miles in 2 wheel drive? Does that assy. turn when in 2wd?
Old Jun 21, 2006 | 12:38 PM
Drew's Avatar
Drew
yes. the whole front end is still locked in and rotating even though you have it in 2wd. both fords and chevy's have the ability to disengage the front axels so they are not rotating. Dodge is always locked in.
Old Jun 21, 2006 | 01:14 PM
DBLR's Avatar
DBLR
Drew,
Being part of the U joint is in the way and a cross member under the shaft how can I tell if I am getting grease in the fitting. Is it easier if the truck is on a hoist and me not on my back on the floor.
Charles
Old Jun 21, 2006 | 02:56 PM
Drew's Avatar
Drew
the best way I know how to get to it is to jack up one front wheel and turn it till you can get the best acess to it
Old Jun 21, 2006 | 09:16 PM
cj5nutz's Avatar
cj5nutz
Junior Member
Dang Drew , thats a tough one to get to. I bought the Napa tool today and rotated the tire untill I got my best shot at it but still, thats a pain. Thanks for the info!
