Turbo Silencing ring
Old 07-07-2006, 09:39 PM
pecdaddy's Avatar
pecdaddy
pecdaddy is offline
Default RE: Turbo Silencing ring
Thanks. That baffle was a real mo fo, seems to be pretty tamper proof. Not as obnoxious as i had hoped. Still dig the sound.
Old 07-16-2006, 04:22 AM
ARMOUR's Avatar
ARMOUR
ARMOUR is offline
Took the silencer ring off tonight and went for a drive but didnt seem to notice any difference, i have a 4.5" straight pipe exhaust too, and seems to be no difference in turbo whine???? WHY???
Old 07-16-2006, 01:32 PM
pecdaddy's Avatar
pecdaddy
pecdaddy is offline
Remove the hard plastic piece from the intake and inside that is the baffle (the cross section), remove that. I had a hard time of it. It is pretty tamper proof, ended up breaking it out.
Old 07-18-2006, 12:06 PM
Drew's Avatar
Drew
Drew is offline
the easiest way to remove it is to get a dremel and cut the very ends of the beveled edge off and the while thing will slide right out.
Old 11-20-2006, 11:57 AM
2000 RAM's Avatar
2000 RAM
2000 RAM is offline
I have a 2000 Ram and have taken out the ring but as I was reading over the forum I see where you talk about( TAKE THE BAFFELING OUT )Does the 2000 24valve have this you are talking about? I took the ring out and I also have the KN set up and I do have the 4" ex-haust but I would still like to get somemore WHINE FROM THE TURBO.I guess I am used of the sound from the Big trucks I drive. If not is there anything more I can try to get more
W_____H______I_____N_____EFeel free to e-mail. Thank you SAM
IF YOU GOT IT....A TRUCKET BROUGHT IT
Old 11-20-2006, 01:16 PM
jakebrake's Avatar
jakebrake
jakebrake is offline
The 2nd gens do not have a baffle. Take out the ring is really easy. If you really want to hear that thing scream. Put an afe on there. I got it loud enough to hurt ears with the windows down
Old 11-20-2006, 04:26 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Welcome aboard 2000 ram !!
Quick Reply: Turbo Silencing ring
