Drews Brew... Explained. (Read Me FAQ)
#61
RE: Drews Brew... Explained. (Read Me FAQ)
I looked at the mmo web site and it states that it is safe to use in diesel engines. The dye is not the same dye used in off road fuel, nor the same concentration. If you go to their website and look under the faq it has this information. Just thought I would let you all know.
#62
Greetings, I'm Pumped having a new 06 5.9 diesel Can't believe its mine.
Should I use DPS ? Drews Brew ? How fast should I cruise on the super slab ?
Leaving on a trip to Utah from MN. Truck has 150 miles on it, sitting on the lot a year..
leaving in 3 days, hope its OK to post here too..can use some help..80 MPH is 2200 R's
Here is my oldtruck on e-bay, one owner,NDH
http://cgi.ebay.com/ebaymotors/ws/eB...;rd=1&rd=1
#63
ORIGINAL: wingit
What is this pic showing ??
#64
thats the connectors for the snow plow.
just shows the condition..
thanks for the well wishes, I like the new truck so much I can't stand it.....
When I got myfirst newone 10 years ago, I thought, this should last as long as I do, then seeing all the miles and wanting a ram diesel, I'm thinking, maybe I want to live longer !!!! got a new one , he he
NOTHING like a great running motor
#66
RE: Drew's Brew... Explained. (Read Me FAQ)
I know I've heard that when folks start using biodiesel sometimes the surfactants in it will cause the fuel filter to clog. Has anyone had anything like this happen in their truck since the additives used in this brew both contain "cleaners" of sorts?
#67
#68
#69
on
At this time I’ve stopped all additives in my fuel for a few tanks to get it all cleaned out and will start again from scratch. When I used Drew’s brew I never had any problems with my truck. In fact put a good 11,000 miles on my truck with PS and MMO with out any problems.
When I started to use 2-cycle oil it was in the wintertime and I noticed a drop big in mpgs. I now have about 3,000 miles on my use of 2-cycle oil and last weekend I had an injector or 2 knocking on my truck while I had PS, MMO and 2-cycle oil in the tank. Though I’m not sure if adding the 8oz of MMO to the mix caused it or what but I can say thank goodness I had some Lucas around. I put 9 oz of Lucas in the tank and drove the truck on the freeway @70-80 mph the 15 miles to town and when I stopped at Walmart I no longer had an injector knock so I can say it is some good stuff.
Anyway this weekend I’ll use 8 more oz of Lucas and put a ton of rock in the bed and take it on an all day run to the Mississippi river then go south to Dubuque and back home to make sure I no longer have any carbon or sticky injectors so that I can start the additive trials again but I'm not sure if I will try the 2 cycle oil again.
