Drews Brew... Explained. (Read Me FAQ)
#72
RE: Drew's Brew... Explained. (Read Me FAQ)
I now have about 3,000 miles on my use of 2-cycle oil and last weekend I had an injector or 2 knocking on
#74
RE: Drews Brew... Explained. (Read Me FAQ)
Just purchased my first dodge, a 2006 Ram 3500 w/ a 5.9 cummins. I was looking at additives, saw the drews brew. Readabout it and would like to try it. But I havea 48 gallon tank on my truck and the mix is for 35 gallons. After working out the math I believe I need to use a mix of 21oz of PS to 11oz of MMO just want to know if this is correct.........
#75
not to crap on anyone here but you may want to read this.
http://www.dieselplace.com/forum/sho...d.php?t=177728
I dont think I would be putting MMO in my fuel tank!
Edited to add: If you want a more printer friendly version here is a PDF version of it
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
#76
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
damm that's not good
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
PSD is way down the list
Time to look at some of the others
number 1 was bio- fuel
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
320:1 ratio
10.4 oz/tank
$3.22/tank
Multi-purpose
400:1 ratio
8.32 oz/tank
$1.58/tank
2)Opti-Lube XPD
256:1 ratio
13 oz/tank
$4.35/tank
Gas and Diesel
640:1 ratio
5.2 oz/tank
$2.60/tank
Multi-purpose
demulsifier
3000:1 ratio
1.11 oz/tank
$0.68/tank
cetane improver
512:1 ratio
6.5 oz/tank
$3.65/tank
1000:1 ratio
3.32 oz/tank
$1.87/tank
200:1 ratio
16.64 oz/tank
$1.09/tank
Lubricity Only
1000:1 ratio
3.32 oz/tank
$1.00/tank
Multi-purpose
640:1 ratio
5.2 oz/tank
$2.16/tank
#77
