Help on lift pump fuel pressure guage install
Old 11-09-2006, 06:58 PM
derherr65's Avatar
derherr65
derherr65 is offline
Default Help on lift pump fuel pressure guage install
Quick question on installing a fuel pressure guage for the lift pump. I've got an electric gauge, sender, banjo bolt, and two washers. I know how to install them, but want to know the start-up or bleed procedure.
Is just turning the key on and off a few times to run the lift pump without starting the engine enough, or is there a better bleed procedure?
Old 11-09-2006, 07:04 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Default RE: Help on lift pump fuel pressure guage install
I don't know your answer, but if you wouldn't mind taking some pics of the install it probably ( definately ) would help others doing this mod in the future.
Thanks der !!!
Old 11-09-2006, 07:07 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
I know that works on the CR motor, not sure on yours... if you can find a fuel filter DIY writeup on the gen 2 rams it should tell you. Also, did you check the manual for info on it? (aka merry christmas thread in the 2nd gen forum is found in a thread tacked to the top)
I recall hearing something about having to bleed the air out of the system...
Old 11-09-2006, 09:34 PM
derherr65's Avatar
derherr65
It will be documented and photographed.
I read that a while back... I don't remember... I'll have to look again.
Old 11-10-2006, 01:07 AM
Mayfair's Avatar
Mayfair
Mayfair is offline
ORIGINAL: derherr65
Old 11-10-2006, 01:12 AM
jakebrake's Avatar
jakebrake
jakebrake is offline
It should be enough just to bump it once or twice. When I did mine, I bumped it once the it fired right off.
Old 11-10-2006, 01:15 AM
Mayfair's Avatar
Mayfair
Mayfair is offline
ORIGINAL: jakebrake
I bumped it once then it fired right off.
We're still talkin about gauges here right ??
Old 11-10-2006, 01:21 AM
jakebrake's Avatar
jakebrake
Yes, when you install the sending unit, you lose some fuel at the injection pump. Before crancking, bump the starter to make the lift pump run to help prime the system.
Old 11-10-2006, 01:23 AM
Mayfair's Avatar
Mayfair
Mayfair is offline
Forget it ....
You TOTALLY missed the joke ...
Old 11-10-2006, 01:26 AM
jakebrake's Avatar
jakebrake
You'll have to excuse my stupidity, I've been up too long today. Good catch, at least it didn't go off in my hand[:@]
Quick Reply: Help on lift pump fuel pressure guage install
