drews mix not working for me
Old Nov 14, 2006 | 02:54 AM
cosmojoe's Avatar
cosmojoe
Default drews mix not working for me
sorry to report drews mix is not doing anything for my mileage?ctd with 5500 miles was getting 16 before the mix. now i'm barely getting 14.5? any thoughts on this? have done nothing diff. as far as addons go everything the same as when i started useing the mix. was actualy getting closer to 16.5 before. real bummer as i was hopeing to be cool to my engine an get better mileage while doing it.
cosmo
ps just wondering am i the only one where the mix dosen't seem to be working for mileage help????????????
Old Nov 14, 2006 | 03:08 AM
steve05ram360's Avatar
steve05ram360
Default RE: drews mix not working for me
it is possible you are now getting a winter blend of #2... my mileage just dropped with the last fillup. definately less pep.
Old Nov 14, 2006 | 03:14 AM
jakebrake's Avatar
jakebrake
5500 sound like its time for an oil change and a new fuel filter. As steve said winter diesel is now in the area. Try a few more tanks before you give it up. I didn't see a big mileage increase until the 3rd or 4th tank. Even if I didn't get the mileage, I still would be using for the lube because vp44's are expensive. Also seems to cut down on some of the rattling under the hood. Knocked a couple hamsters off the wheel
Old Nov 14, 2006 | 03:28 AM
cosmojoe's Avatar
cosmojoe
oil changed at 5000 fuel filter also
Old Nov 14, 2006 | 11:59 AM
Drew's Avatar
Drew
winter blend fuel. . .we got the blend here a few weeks back and I can tell a huge difference.
Old Nov 14, 2006 | 05:20 PM
GlenninTexas's Avatar
GlenninTexas
I've been using Drews mix for several months and also noted about a 1 mpg drop. Fresh oil, filter, no other changes.
Regards, Glenn
Old Nov 15, 2006 | 03:40 AM
NickBeek's Avatar
NickBeek
It didn't seem to do much for me either.
Old Nov 15, 2006 | 02:05 PM
Hiloram's Avatar
Hiloram
I don't know much about the mileage improvement because I am to lazy to caculate it. I can tell you that it sure makes the engine run smoother. My friend has the virtually the same truck as I do and when I pull up next to his you can really here the difference in the sound of our engines.
Old Nov 15, 2006 | 02:17 PM
steve05ram360
this talk of the winter blend fuel... if I switched to the grey bottle would it make a difference? I've been using the white for the most part as I never really saw a difference between the two. now with the winter crap here I'm wondering if it'll make any difference.
Old Nov 15, 2006 | 05:39 PM
DBLR's Avatar
DBLR
On the grey bottle it claims to boot the Centane higher then the white does so give it a try and find out! Nothing to lose but something to gain if you try the grey bottle.
