oil filter, diesel with clean oil?
Old Nov 15, 2006 | 07:52 PM
Drew's Avatar
Drew
Default RE: oil filter, diesel with clean oil?
I'm pretty sure the scotts would work, but I believe there is a special roll that needs to be used that has a more packed design on the roll.
Old Nov 15, 2006 | 08:03 PM
Mayfair's Avatar
Mayfair
Yo ..... are we REALLY talking about TOILET PAPER over here ???
[sm=dontgetit.gif]
Old Nov 15, 2006 | 08:06 PM
derherr65's Avatar
derherr65
Like this?
[IMG]local://upfiles/48120/8554623C6D574A128E8DE7E9895D76DB.jpg[/IMG]
Lol, poor Mayfair. Always lost in the middle. Well, it's as close to rolled paper as toilet paper, but yes.
Old Nov 15, 2006 | 08:18 PM
Mayfair's Avatar
Mayfair
Here's a roll that you can use ....
Old Nov 15, 2006 | 08:24 PM
derherr65's Avatar
derherr65
"For optimal performance of the Frantz Oil Cleaner/Filter, it has always been recomended to use a 2 ply 500 sheet per roll, facial quality Toilet Paper. The purpose for these specifications is so that you will obtain the most densely packed roll of TP available. If you cannot find a 2 ply 500 sheets per roll in your favorite grocery store, we suggest that you try the comercial or janitorial supply companies to find some. If you still cannot find or buy any, we do have it for sale either in four packs or by the case! We have also heard that a 1 ply 1000 sheet TP has also worked(Scott 1000)." From Frantz
Old Nov 15, 2006 | 09:00 PM
Mayfair's Avatar
Mayfair
OK ... what is the link to this toilet paper filter thingy? You've got me curious now.
Old Nov 15, 2006 | 09:07 PM
derherr65's Avatar
derherr65
Lol, yeah, that's kinda how I started out looking at them. First link is the guys that own frantz now. Second is a guy, completely independant, running them. He has oil tests and all.
Frantz bypass filters
cumminsforum
Old Nov 16, 2006 | 05:00 AM
Mayfair's Avatar
Mayfair
WOW reading that whole second thread really makes you think about it huh?
How much are they?
Old Nov 16, 2006 | 10:53 AM
Drew's Avatar
Drew
I stand corrected then. . .hmmmmmmmm
Old Nov 16, 2006 | 02:03 PM
derherr65's Avatar
derherr65
$145 for the canister alone, $200 for the whole kit plus 8 refills. I really like the $0.70 filter change part. Think how long the stock filter could safely last if it was only required to take out the chunks. And oil changes could be extended somewhat. How much would depend on oil analysis numbers. I'm thinking change the TP every 2000 miles or so, though I'll probably only put 500 miles on the first roll. Part curiosity and part soot load even after a fresh oil change. Now this is on my 1982 3.0L Turbo Diesel Mercedes. It's a fair amount cheaper than a 2002 cummins Ram. I'm considering something like the fs2500 for a truck. Unless the results on the mercedes are just too good.
Same idea, different company.
Motor guard
More traditional solution, Check out the videos, amazing!
FS2500
