Swapping Factory Stereos...
Old Jan 4, 2007 | 08:01 PM
twotrack68's Avatar
twotrack68
Default Swapping Factory Stereos...
I have an opportunity to swap out my factory 6 disc stereo for a factory navagation 6 disc stereo from an '06 Charger. I currently have the upgraded Infinity system. Besides changing out the bezel/trim pieces, is this a plug & play deal or is there some additional wiring involved? Thanks for any info!
Scott
Old Jan 4, 2007 | 08:21 PM
triton's Avatar
triton
Default RE: Swapping Factory Stereos...
it's a direct replacement. As you said.... all you need is the bezel.
I did the same thing with mine.
Old Jan 5, 2007 | 12:54 AM
bert0168's Avatar
bert0168
If you don't have plans for the stock 6 disk, I might be interested in it for my 05 Ram with single disk if it is a direct swap. If interested let me know what you want for it.
Old Jan 5, 2007 | 12:15 PM
rudy_t2004's Avatar
rudy_t2004
+1 FOR THE SIX DISK, unless someone has the navi that I can take off of there hands
Old Jan 5, 2007 | 02:09 PM
MrSlug's Avatar
MrSlug
ORIGINAL: triton
So you do not need another antenna for the GPS? I guess the Sirus antenna on the 6 disc also acts as the gps antenna?
Old Jan 13, 2007 | 01:57 AM
twotrack68's Avatar
twotrack68
Ok, so I installed the navi unit but it seems I may be missing the little 1/4" square plug for the navi antenna. I tried the navi feature & it tells me that the antenna is not plugged in. Is this standard on all trucks? I looked all over behind the dash & cannot fine the antenna plug for the navi feature.
Scott
Old Jan 13, 2007 | 02:10 AM
KYSkipper's Avatar
KYSkipper
GPS is going to have to have an antenna somewhere. I kind of doubt it's just in there without the GPS. I would think if there is a Y plug for the Sirrus antenna that would work. GPS's are funny about their antennas. Whatever that unit requires is what you'll probably have to use. I know on the marine units if you swap from Lowrance to Garmin the antennas aren't necessarily interchangable. If they are, most of the time they don't work right . I've never seen a GPS with a square plug for the antenna wire. Most and BNC connectors.
Skipper
Old Jan 13, 2007 | 02:30 AM
twotrack68's Avatar
twotrack68
I swapped a factory 6 disc for a factory 6 disc/navi unit. All of the other connections were exactly the same. I'm just wondering where I find the small square plug for the navi feature or if it's something that I need to get from the dealer & hook up somewhere.
Old Jan 13, 2007 | 03:33 AM
KYSkipper's Avatar
KYSkipper
I realized that you swapped radios. I would assume that most D/C radios are basically interchangable in the vehicles. There's no reaon to change the power or speaker wiring harnesses. That said, a GPS unit is a whole other animal. GPS antenas are specifically loaded for a paticular unit. You can stick a coat hanger in the radio antenna hole and it'll probably work. You can't with a GPS antenna. Same reason the Sirrus won't work off the regular antenna but has to have the satellite antenna.
I'd go to a lot and find the GPS antenna on one that has a navigation system on it. If in fact they are using the Sirrus antenna for the GPS antenna, then likely the dealer has a splitter cable for it. It may be that there is a different Sirrus antenna for the GPS combo that has both modules in it. It would be kind of like a Dish antenna with dual lnb's or dual bands where it has the double bubble thingy on the arm in front of the dish.
http://gpsnow.com/gmmap378.htm#acc
That is a link to a place that sells Garmin accessories. Scroll down about half way on that page and you should see a couple antenas. The top little square on only gets GPS. The larger round one gets XM and GPS.
Is there an antenna out from the Sirrus box to the radio? If so, you probably just need the connector wire from there to the radio, if not, it could be more complex.
Skip
