Leaking Oil...
#32
Hey guys! Where is the plastic bottle or container for oil overflow? Front or rear of engine?top or bottom? near what ? I need to check it. Somebody told me is located in the front of the enginebut WHERE!!....I JUST CAN'T FIND IT!! [:@]....not even in the Haynes manual. 98 Dodge Ram 1500 (5.2)
#34
Is a little plastic bottle that supposed to bemounted on the front of the engine? This container catches oil blown out your crankcase vent tube and needs to be emptied every oil change or it runs over. A lot of fast lubes and independent garages don't empty this because they don't even know it is there.
#36
#37
HPCR's dont have this bottle, only the VP-24v's do, and then some dont, it was an emissions thing.
however putting a bottle at the end of the blow by tube is something that can be done if you want to keep the underside of your truck clean.
I just hope you are not haveing excessive blow by from a compression ring going out or a cracked piston.
#38
