Stock rims 315 tire?
Old Feb 14, 2007 | 04:07 PM
Belldar's Avatar
Belldar
Default Stock rims 315 tire?
Hey guys what are your thought on putting 315/70R17 on my stock aluminum rims. I have seen it but is it bad? The tire is rated for a 8.5 to a 10 inch rim. I think the stock ones are 7.5 aren't they? Please let me know what you think becasue i really want bigger tires and i really like my rims now.
Also with a manual 6 speed in my 2006 do you think a 35 inch tire will help my fuel economy since the RPMs are so high at high speed?
Old Feb 14, 2007 | 04:09 PM
MrSlug's Avatar
MrSlug
Default RE: Stock rims 315 tire?
The stock rim should be a 17X8 (mine were). I would expect your fuel econ to drop about 1 mpg with 35" tires. Just think of all the extra rotating mass the larger tire has.
Old Feb 14, 2007 | 04:17 PM
Belldar's Avatar
Belldar
How do the 33inchers fit? Am i retarded for wanting 35s?
Old Feb 14, 2007 | 10:30 PM
BlkRam69's Avatar
BlkRam69
33's work great with zero rub. I originally wanted 35's however went with the lesser becouse I couldnt get the 35's I wanted at the time.
I'd love to run 35's just for a day to see if I liked them but I havnt been able to talk my tire guy into a test drive.
I will say however thatmy trucks overall ride and drivability took a turn for the worse after I went to the 33's. It took about 3 brushes wit the dreaded "Death Wobble"[sm=scared09.gif] before I broke down and bought a gas charged steering damper from KORE.
Immediate and noticable imrovement!
Old Feb 15, 2007 | 02:22 PM
Belldar's Avatar
Belldar
What tires are you running Blk Ram69? I was going to run toyo MTs. I thought the newer dodges didn't have the death wobble. I am deffenently planning on getting the Kore chase kit B4 i do the bigger tires any ways. How much was the steering damper? I am interested. The chase kit i can get for $2,300 shipped.
Does any one out there run 315's on their stock rims? If so does it were the tires weird or more quickly?
Thanks
Old Feb 15, 2007 | 04:44 PM
Do_What's Avatar
Do_What
you could use the 315's on the stock rims although they would have more of a rounded look to them instead of a squared off look to them (am i making any sense?) Working in a tire store i have done some i personally don't like the look.
Old Feb 15, 2007 | 06:24 PM
BlkRam69's Avatar
BlkRam69
I went with the trxus M/T's http://www.intercotire.com/site35.php becouse everyone I talked to couldnt put there hands on the Toyos at the time. I think Toyo will still be my next tire I just need to get my wife to let me buy a set now while I can get them.
As far as the death wobble goes,.... At first the truck drove like a dream. I did notice on some roads the bumps would last a little longer. Then as I started to mod it (tires, leveling kit) I got my first taste of the "wobble".
I was excelerating and hit a bump and it felt like it kept building to the point I had to slow down from 55 to about 35 before it passed. This happened 3 more times before I broke down bought the stabilyzer.
Old Feb 15, 2007 | 09:37 PM
caytos's Avatar
caytos
Here are some Pics of BFG 315/70-17's on stock rims.
Note the small rub on the upper control arm. This is the Drivers Side. Passenger side not as bad but still there.
http://i162.photobucket.com/albums/t...verSideRub.jpg
I think it fills out the wells nicely.
http://i162.photobucket.com/albums/t...t/DSC02277.jpg
http://i162.photobucket.com/albums/t...t/DSC02282.jpg
http://i162.photobucket.com/albums/t...t/DSC02283.jpg
I have more pics with a large ruler in the frame to give clearance dimensions. PM me and I will send.
This is my first post with pics. Hope this works.
Old Feb 15, 2007 | 11:34 PM
Ben D.'s Avatar
Ben D.
Take a look at this months 4x4 off road mag. They have a CTD project truck and they say that on a 2500 you can run a 35x12.50 tire on the stock rims with only mild rubbing at full lock. I would think that small wheel spacers would fix this maybe like 1 inch wheel spacers would do the trick.
