fuel filter
Old 02-28-2007 | 02:02 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default fuel filter
what would be the recommended way of changing the fuel filter on my 93 d250 5.9l...?
the filter screws on like the oil filter with a sensor plugged into the base.
Old 02-28-2007 | 12:22 PM
Drew's Avatar
Drew
Default RE: fuel filter
the best way is to disconnect the sensor(I think it is just a fuel heater), crack open the drain **** and then pull it off. then before installing the new filter fill it up with fresh fuel, screw it on and re-install the wireing.
you may have to crack the injector lines to purge all the air out but that is the best way to do it.
Old 02-28-2007 | 12:40 PM
Kev_n_AZ's Avatar
Kev_n_AZ
thx for the reply drew. Guessin Ill just take it to the mechanic I bought it from since he replaced the injector pump anyway.
Old 02-28-2007 | 12:58 PM
Drew's Avatar
Drew
it only sounds complicated but it is rather easy to do. . .if you can change the oil you can change the fuel filter.
Old 02-28-2007 | 01:06 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: Drew
the oil??? lets not go there.....made a hell of a mess last night with those 12qts pourin out like a broken dam!!!!
still "warmin up" to the diesel myself.
Old 02-28-2007 | 02:31 PM
Drew's Avatar
Drew
HA HA HA. . .aight
Old 02-28-2007 | 03:15 PM
Kev_n_AZ's Avatar
Kev_n_AZ
purchased the wrong size oil container to catch it all...
next time im modifiin a 5gal bucket to slip underneath. .
Old 02-28-2007 | 03:36 PM
Drew's Avatar
Drew
Ive got a 5 gallon covered catch pan from autozone that works good. . .the inlet hole is a bit small for the amount of flow from the pan. but I just plug it up for a few seconds once and it's good.
Old 03-01-2007 | 01:09 AM
Kev_n_AZ's Avatar
Kev_n_AZ
my mechanics assistant told me to do the fuel filter myself today. explained that the minute amount of air that may get in the injector system will bleed out on its own. (or i can hit the bleeder valve). guess Ill give it a whack thursday.
Old 03-01-2007 | 01:18 AM
Drew's Avatar
Drew
let us know how it goes. . .
Quick Reply: fuel filter
