What the hell...
Old 03-22-2007 | 09:55 AM
RetroCow's Avatar
RetroCow
Default What the hell...
What the hell would cause the engine and tranny temps to "overheat"?
I don't ever let them actually overheat but there have been a few times in the past few weeks where I have had to pull over for a few minutes.
Could it be the fan clutch or the fan belt slipping? Does the '01 have a stock trans cooler?
Now that I think about it, could hot intake air cause the radiator (?trans cooler?)to be less effective because of its location behind the intercooler?
It is going to start getting really hot here in southern Arizona real soon. I need to figure this out ASAP.
Thanks in advance for any input,
Mike
Old 03-22-2007 | 10:02 AM
Drew's Avatar
Drew
Default RE: What the hell...
do you have a '53' block???
Old 03-22-2007 | 10:05 AM
RetroCow's Avatar
RetroCow
Don't know...where do I look?
Old 03-22-2007 | 11:06 AM
Drew's Avatar
Drew
first of all. . .look at the block right behind the exhaust manifold, if you see discoloration or smell coolant, then you'll realy know, however if you crawl under your truck and look at the front of the engine just above the oil pan and see the number '53' in two inch numbers then you'll know. the number can be on either side of the block. the last pic is one that had a massive crack, but was repaired.
Old 03-22-2007 | 12:16 PM
RetroCow's Avatar
RetroCow
I don't see a 53 or any leaking...
All I see is a 9A3, I thinkthats what it is...
Old 03-22-2007 | 12:27 PM
Drew's Avatar
Drew
the next thing I can think of would be your radiator might have some corossion blocking the passages. . .when was the last time you changed the coolant. also if you have alot of gunk come out you might need to have the radiator rodded out.
Old 03-22-2007 | 12:30 PM
RetroCow's Avatar
RetroCow
Would that also cause the tranny to overheat?
I will flush the radiator this weekend, thanks
Old 03-22-2007 | 01:30 PM
Watermelon's Avatar
Watermelon
If the radiator is stopped up, the transmisson lines cool through the radiator. low or no water flow will cause both to heat up.
Old 03-22-2007 | 05:17 PM
Mayfair's Avatar
Mayfair
pfft ... I couldn't tell you the last time I changed my radiator fliud.
How do you dispose of thatold coolantagain? I'll admit that back in the day it would just hit the drain, but I'm sure that's no longer appropriate now a days huh?
Old 03-22-2007 | 05:47 PM
Drew's Avatar
Drew
I know NAPA, Autozone, Pep Boy's, o'riley and others will take it.
Quick Reply: What the hell...
