Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
To Lower or Not
Old Mar 22, 2008 | 03:52 PM
roadking954's Avatar
roadking954
Default To Lower or Not
I have seen several o5 Qc lowered but which is the best kit? I would like to drop
the rear enough to be even with the front, just do not want to slam it.
Any suggestions? I also have two, still in the wrapper owner manual kits for the 2006
if any one needs them.
Old Mar 22, 2008 | 09:36 PM
ndn01's Avatar
ndn01
Default RE: To Lower or Not
hi, have you had a chance to measure the height of the frontfender to the ground then measure the rear fender to the ground,maybe measure the fenders to the tires front and rear sometimes the measurement could be different,check bothto be sure.then that would give you a starting to go by;how much to lower and what type of drop shackle you need,maybe one or two inch drop.i agree you don't want to slam it, some trucks don't vibrate after lowering them but a lot do especially qc;two piece drive shafts.
Old Mar 22, 2008 | 10:36 PM
Midnight Runner's Avatar
Midnight Runner
I like that look alot.
Old Mar 22, 2008 | 11:30 PM
CarGuyOhio's Avatar
CarGuyOhio
2" lower in the rear will level the truck.
Old Mar 25, 2008 | 11:24 PM
Texasdodgevet's Avatar
Texasdodgevet
OK, 2in in the rear will even out the truck. Thats exactly what I want to do. Same truck (05 QC) 2WD
How do I do it? Dealership? Online??
Thanks guys!
Old Mar 28, 2008 | 09:00 PM
CarGuyOhio's Avatar
CarGuyOhio
www.x-metal.com
Old Apr 3, 2008 | 01:20 PM
Midnight Runner
ORIGINAL: Texasdodgevet
Thanks guys!
I would like to know that to.
Old Apr 3, 2008 | 01:21 PM
Midnight Runner
ORIGINAL: 94rt10ohio
www.x-metal.com
I can't get in to this website.
Old Apr 5, 2008 | 11:04 AM
roadking954
Xmetal.com has a great lowering kit for the QC except you
have to relocate the rear diff on the springs and then use
the supplied shackles to fine tune it. Then you also need to check drive shaft pinion angle or the vibrations will shake you out of the truck.Would like to find a simplier solution. Anybody know of one for a QC ?
Old Apr 8, 2008 | 12:29 PM
alftuckin22s's Avatar
alftuckin22s
Hit this guy up he should have something for you
http://www.slammed1suspensions.com/
