Fuel pump and coil just quit??????
Old Aug 22, 2009 | 11:08 PM
droptines's Avatar
droptines
Default Fuel pump and coil just quit??????
Let me introduce myself,
The name is Matt, and I'm new to the forum. I've just aquired a 1994 dodge ram van, with a 318. The van was given to me for helping out my father inlaw.
The problem, about six to eight months ago he came home from work shut the van off, and it never started again. He worked on it for awhile, and then moved it outback and bought something else.
It is not firing, and the fuel pump is not working. From troubleshooting I have not found any blown fuses, and I know that the coil does not have any voltage to it. From reading the forum I've found that some of you have had similliar problems. I've read about crank shaft postioning senors and auto shutdown relays. What do you guys with much more expertise that me think.
Thanks
Old Aug 23, 2009 | 03:16 AM
landyacht318's Avatar
landyacht318
At the risk of being corrected by those more knowledgeable, you must start with the ASD relay. I don't know about a '94, but when my ASD relay is being a beetch, jumping the 2 fatter wires will allow the fuel pump to engage on my '89.
You should provide more detail for those more informed to be able to point an arrow at something.
Old Aug 23, 2009 | 08:36 AM
droptines's Avatar
droptines
I don't know which is the ASD relay, There are two relays under the dash by the steering colum. I've switched these two relays and there was no change. I dont have much more detail than that yet.
I'm going to get down and work on it one day these week, and see if I can find out which one is the ASD relay. And i'm also going to pull the crank shaft sensor and just see how it looks.
Old Aug 23, 2009 | 10:47 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
landyacht318 is correct, you should be looking at your ASD/Fuel Pump relay assembly to make sure power is going in and out of it. It's not under the dash, so you're likely looking at the wrong item. Look for the 2-relay assembly under the hood, mounted to the firewall.
Old Aug 25, 2009 | 07:59 PM
cudajim's Avatar
cudajim
I also have a 94 with a 318 but have never had the fuel pump quit. If you need to get to it however you'll need to drop the tank. I'd check the relay first!
Old Aug 29, 2009 | 06:54 PM
droptines's Avatar
droptines
Ok,
I found the asd and fuel pump relays. I pulled them and they looked to be in bad shape, both of them had water in them. I replaced both relays asd/fuel pump. And nothing changed, no voltage to the coil or fuel pump. I was short on time but I did have someone try to crank the van while I felt the relays, to see if they were picking. Niether relay was picking asd or the fuel pump. I pulled the crank sensor, it looked good. I know a bad crank sensor will cause the problem with 0volts at coil, but would that also interupt the voltage to the fuel pump? I guess so if the voltage to the ASD relay comes from the crank sensor, but I don't know if it does. I'm going to look at the schematic and see what I can find out.
Any suggestions?
Thanks
Old Aug 29, 2009 | 07:13 PM
kev2's Avatar
kev2
ck red wire at ASD & FP relay should be hot 12v...
ck Dk Blu wire relays shoulb be 12v with key on
to confirm ck for voltage at injectors key on
looking like fusable link,or ign switch
Old Aug 29, 2009 | 10:11 PM
droptines's Avatar
droptines
thanks,
I will check those tomorrow.
I was also wondering about the ignition switch. Are you referring to the tumbler or something else? My old ford had a ignition module under the dash, does the dodge have anything like that?
Old Aug 30, 2009 | 08:37 AM
kev2's Avatar
kev2
the lock and switch are not the same...
Old Aug 30, 2009 | 11:46 PM
droptines's Avatar
droptines
ok,
I checked the voltages at the relays and at the injectors. Here are the results.
0 volts at the injectors.
Relays:
Key Off
ASD relay
red wire=ground
dark blue wire=ground
blue/w wire=ground
Key on
ASD relay
red wire=ground
dark blue wire=12vdc
blue/w wire=12vdc
Key Off
Fuel Pump relay
red wire=ground
blue/w wire=ground
key on
fuel pump relay
red wire=ground
blue/w=12vdc
What do you guys think about that.
the blue wire had 12vdc with the key on, the red wire was just ground no matter what. I did check the injectors and I had 0vdc. Should the red wire be grounded? What is the ouput of the relay? From what I can tell the blue and blue/w wires are the coil, and the red wire is the input. The fourth wire on the relay is green (is this the output) and it is grounded no matter the position of the key switch. I tried to jump between the dark blue wire and the green wire, nothing happened. it seems to me that the red wire should not be a ground. What do you think?
Thanks
