"NO BU5" Engine died
Old Jan 24, 2010 | 10:16 AM
1LowToy's Avatar
1LowToy
Default "NO BU5" Engine died
I have a problem with work van a 2002 Dodge 3500 van. It's been raining in cali for the past two weeks and I went through a wet spot (3" deep?). The engine died. When I turn on the ignition I have no gauges, the odometer comes on but in a few seconds it flashes on and of the goes to NO BU5. The tow truck came and it fired up for him making me look like a schmuck. The next time I tryed to start it, same thing. The next morning no more intermittent problem It's dead. Same No BU5 from the odometer. I also noticed no relays are clicking to do their jobs.
By the way what's an ASD relay and wheat does it do?
I need my van back it's my office and my job
Old Jan 24, 2010 | 03:05 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
The ASD (Auto Shut Down) relay supplies power to the coil, injectors, and fuel pump; just to name a few of the important ones.
A no bus message means a loss of communication between the odometer and the PCM. This could be the result of loose or broken wiring or a bad PCM.
Old Jan 24, 2010 | 05:30 PM
1LowToy's Avatar
1LowToy
Could my loss of power be caused by going throgh some water and getting the speed sensor or other sensor wet?
Old Jan 24, 2010 | 06:26 PM
alloro's Avatar
alloro
Not so much if the sensors get wet as the wiring to them. Water is conductive and if the 5 volt sensor power is getting grounded out by the water, then most things will not work until it dries out.
Old Jan 25, 2010 | 08:31 AM
1LowToy's Avatar
1LowToy
So if the O2 sensor, CPS or any thing sensor gets wet the ASD will take over and shut down my world?
Old Jan 25, 2010 | 01:38 PM
landyacht318's Avatar
landyacht318
I would check for moisture at the ECM connectors as well. Disconnect battery first.
Also look at any wired connections at the tranny. Dry, clean contacts an apply di-electric grease.
Old Jan 25, 2010 | 06:31 PM
alloro's Avatar
alloro
Not so much take over as de-energize. If the PCM ceases to receive input from the sensors, then the PCM thinks something is wrong and shuts down the relay.
Old Jan 25, 2010 | 07:45 PM
1LowToy's Avatar
1LowToy
So if there is moisture on or in the wiring harness making contact with a system sensor circut the computer sences the short and shuts down, ands no limp mode? I tried down loading fo codes but no luck. Does the computer shut off entirely?
Old Jan 25, 2010 | 08:01 PM
alloro's Avatar
alloro
I tried down loading codes but no luck.
This is not a good sign. Getting a "no bus" message along with not being able to read codes in 9 out of 10 cases means the computer is no good.
Old Jan 26, 2010 | 07:03 AM
1LowToy's Avatar
1LowToy
Could this be water related as I drove through like 2.5 to 3" of water? If so I should turn this van into a convertible and keep it for summer pleasures only.
