1991 B250 headlight issue - help!
Old Feb 7, 2010 | 03:54 PM
ttlphotography's Avatar
ttlphotography
Default 1991 B250 headlight issue - help!
hey guys;
I finally solved the starting issue with this van. runs nice and smooth now.
I was doing a walk around backyard pre-inspection and noticed that i have turn signal lights that work, hazard lights that work.
What i DONT have is headlights, running lights or brake lights. I know bulbs are good. I also checked all fuses in the panel that is in the glovebox on the left side under the cover. Those are all good.
I was thinking maybe the headlight switch itself since it has a ton of wires attached to the plug that connects to the headlight switch. So i got a replacement, installed it and still have nothing. So im a tad confused now.
Any suggestions as to what to look at, where to look, what to try next?
thanks
tom
Old Feb 7, 2010 | 04:29 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you ck under the hood for a fuse box? Or a PDC?
Old Feb 7, 2010 | 04:48 PM
ttlphotography
sure did. looked everywhere but if its in there, 3 guys cant find it.
both books i have make mention of it, but as to the location of said fuse box/pdc is a mystery.
book also mentioned "this relay" and "that relay" but no pictures, locations mentioned. so we resorted to tracing wires in hopes of finding some fusible links or something that would be the problem or lead us to the PDC/fusebox.
thats part of the confusion. it shouldnt be that hard to locate.
its a standard B250 3/4 ton extended van with the 5.2L 318 V8 motor.
Old Feb 7, 2010 | 05:09 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
The 91 still used fusible links, there is no PDC. The fusible links can be found in the wiring harness up around the power brake booster.
Old Feb 7, 2010 | 10:57 PM
ttlphotography
would these fusible links be wrapped up inside the electrical wiring bundle thats all wrapped up in electrical tape?
I'll take a few pix of the brake booster side and post them here.
Old Feb 7, 2010 | 11:45 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Yes they are.
Old Feb 8, 2010 | 09:43 AM
alloro's Avatar
alloro
See if this helps you out at all.
Old Feb 8, 2010 | 11:45 AM
ttlphotography
excellent alloro!! least thats something for me to go by visually.
much appreciated.
now to just get thru the layers of electrical tape wrap :/
i'll report back here once i get all that exposed.
thanks again!!
Old Feb 8, 2010 | 08:59 PM
landyacht318's Avatar
landyacht318
I don't know about a '91, but my '89 has all the fuses inside the glove box, and all the fusible links were behind the brake booster, wrapped in electrical tape, and apparently always wet for weeks after any rain.
Old Feb 9, 2010 | 02:01 PM
ttlphotography
found the culprit. fusible link. kinda a pain to dig out from behind the brake booster, but found it nonetheless.
appreciate the insight and assistance.
thanks
tom
