92/ ram van 318 no spark or no power to injedtor's
Old Jun 22, 2010 | 06:52 PM
doubledssqueezer@hotmail.com's Avatar
Default 92/ ram van 318 no spark or no power to injedtor's
running fine just quit .pulled ever fuse all good . changed coil and CMP sensor and the CKP sensor.don't think i'm getting any power to my ECM .
how would 1 find out if i'm getting power to the ECM .. THE CHECK ENGINE light . won't come on even with key is in the on . book say should come on for 5 sec ,light did work the same day it quite running . so can't look to see what code's are up. all in line fuse's look good . thinking a new ECM ?
thak's
Old Jun 22, 2010 | 07:59 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Check/Replace your ASD relay. In a 92 I think it's mounted to the firewall, it might also be a 2 relay assembly for both the ASD and fuel pump relays.
Old Jun 22, 2010 | 08:25 PM
yes i see them 2 of them side by side . and AutoZone don't carey them . tomaro dealer . thank's hope that's it
Old Jun 22, 2010 | 08:42 PM
alloro's Avatar
alloro
You should first check to see if they're putting out power instead of just swapping them out, just in case they're good.
Old Jun 22, 2010 | 08:57 PM
ok how would i do that .with a light tester ? in the plug . just unplug 1 and test it .
Old Jun 22, 2010 | 09:30 PM
alloro's Avatar
alloro
For one, if you hold your hand on it and have a helper turn the key on and off you should be able to hear or feel a mild click from it. Second, clip a test light to a good ground then with the key off and the relay still installed, check the red wire and Dark Green wire with the orange stripe running down it with the test light. The red should have power but the DG/O wire should not. Now turn the key on and both wires should have power. With the key on, if the DG/O wire is still dead then the relay is no good.
Old Jun 22, 2010 | 10:43 PM
ok here's what i got say relay 1 has a dark blue key on power, key off no power
green no reading , black touch to the test light and it click's with key on
RED. no reading
relay 2, 2 dark blue same hole touch to the test light and it click's with key on.
2 light blue same hole no reading ,1 green no reading
2 RED same hole no reading. so i'm guessing no power going to them ?
hope that help's thank's for the help again
Old Jun 23, 2010 | 04:35 PM
thank's alloro i found a bad wire . was behind the brake boster. was 1 white going to 2 red's not far from battey thank's again
Old Jun 23, 2010 | 10:51 PM
alloro's Avatar
alloro
Originally Posted by doubledssqueezer@hotmail.com
thank's alloro i found a bad wire . was behind the brake booster. was 1 white going to 2 red's not far from battery thanks again
That's a fusible link not a wire. You DO NOT want to replace that with any old piece of wire. It's function is to burn up during an overload to prevent harm to the rest of the wiring harness.
Old Jun 23, 2010 | 11:05 PM
alloro's Avatar
alloro
Read this thread, it has some decent information about fusible links.
https://dodgeforum.com/forum/dodge-r...ssue-help.html
