Band on tour needs help!! Engine just shuts off!
Old Jul 15, 2010 | 01:31 AM
landyacht318's Avatar
landyacht318
The ASD relay can be tested and replaced easily. The EGR valve can also be tested/ cleaned and reinstalled with the vacuum line removed and plugged rendering it inoperable so that it cannot open and get stuck and possible cause stalling. The EGR valve is only for emissions. I remove and clean mine before every emissions test, and disconnect and plug the vacuum line right after passing.
The PCM is a nightmare to definitively diagnose without replacement to see if it cures the problem.
Old Jul 15, 2010 | 08:28 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by 1993-B350-1TON-15PASS-5.9
asd or pcm? or egr?
Sure it could also be one of these, but the coil is more likely and it is one of the less expensive items to change; that's why I suggested it first.
Old Jul 15, 2010 | 12:31 PM
1993-B350-1TON-15PASS-5.9's Avatar
cool man, were going to try that first! plus the tune up.
Old Aug 3, 2010 | 01:30 AM
update: code was 25 and 37.
we replaced the AIS as indicated in code 25. and yes, the ais motor sucked and needed to be replaced.
but does anyone have any ideas about this code 37 junk?
Old Aug 3, 2010 | 11:07 AM
alloro's Avatar
alloro
If your tranny has a lock-up converter it means there's a problem with the lock-up circuit. If you don't have a lock-up converter, then it usually means your neutral safety switch isn't working correctly.
Old Aug 3, 2010 | 03:17 PM
Hmmm...what would maybe by some symptoms of this you think?
The band is going on tour again, and this is the only code i get, we fixed the problem that i started this thread on, so thanks!
Old Aug 3, 2010 | 03:35 PM
also, if you look on this page at code 37 it doesnt even fit the year of our vehicle.... so i dunno...
http://www.allpar.com/fix/80s-codes.html
Old Aug 3, 2010 | 03:38 PM
alloro's Avatar
alloro
1. Able to start in gears other than Park or Neutral.
2. Reverse lights not working or turning on other than when in reverse.
Old Aug 3, 2010 | 04:04 PM
Old Aug 3, 2010 | 05:13 PM
hmmm niether.....you think this is a code maybe malfunctioning or just like a voltage type code?
