MPG improvements
This has been an on going experience for the past two years of what works what does not.
For the longest time, the Ram Van B2500 12-passenger, V8 5.2L/318cid Magnum, 36-gallon tank, with the 46RE, 3.92 rear, and the heavy weighted frame + 8-lug wheeled suspension has not managed to hit above 14mpg in a very long time. I just thought it was high mileage. After doing some digging (reading and experimenting) of what these ultra marathon mileager's are doing, I set out to try a few reasonable things.
We had just finished a family trip from Nashville to FL; 10 of us all packed in with the goods. From fill up to refill a few times, we averaged 18.59mpg. On the tank full that did not have the mountains, rush hour traffic, no construction, no sitting on the interstate due to accidents, the van did an amazing 19.7mpg humming along at 65mph. To see the mileage OD turn past 400 and it was just above a 1/4 tank was shocking. Usually, 340-360 miles per tank was the best this van could do.
Here's a few of the things that helped.
* Brakes
- Tune in those rear self adjusters from keeping the drum brakes from dragging.
- If the brake hoses are over 10 years or the van has sat for a very long time, replace them.
- Find a very low friction and high temp bearing grease that has Molybdenum and repack the front inner and outer bearings.
(My van is using a blue lithium bearing grease from the Tractor Supply store TSC.) <---DO NOT DO THIS. I just repacked again with a Molybdenum Lithium grease today!!! <--- DO THIS.
- Bleed the lines very well.
- Clean the front pad guides on the calipers or ensure that the metal guide clips are not binding the pads from moving.
* Exhaust
- Recently, my CAT and muffler went bad last Fall. I had opted for a high flow CAT, high flow exhaust. Plus where the two pipes come together before the CAT, the OEM has them pinched somewhat restricting good flow. Oh, after the CAT run with 2-3/4 or 3-inch exhaust pipe.
* Tires / suspension
- Chrysler has a TSB mentioning that the load-E tires for handling, safety and mpg are ideal for the Magnum series vans that have the 8-lug wheels. The previous Yokohama tires were not ideal for my van; they wore faster, to soft on the road, traction degraded within 6 months. The BFGoodrich Commercial T/A's load range E are still doing well, traction is holding, tread wear has not even been noticed.
- Alignment is really needed too. Don't go shops with the old school alignment methods. The newer last alignments are dead on.
- Have the suspension looked over for anything that may be failing. (control arms, etc ...)
* Rear Axle
- Chrysler has a TSB out for using 75W90 now in the rears vs. the 80W90. This helps with fuel mpg. While in Georgia, we had visited Summit Racing at exit 216 on I-75. I had picked up a second bottle of Red Line 75W90 synthetic.
* TB
- Other than doing the entire TB replacement with a Fastman TB ( http://www.thefastman.com/Throttlebodies5x.asp ), I've taken the DIY approach and ground down the TB two barrels on the MAP sensor side and didn't touch the IAC side. If you do the TB barrels all around, expect loud rushing noises while at idle and possibly idle issues. Otherwise, this will improve the mpg, Hp, and throttle response. This photo shows all sides ground and smoothed down.
* Engine
- Plugs are the Autolite AP5224 (single Platinum) side gaped like racing plugs. There are at least three threads here in the B-van section talking about this topic. No sense doing that all over again.
- New 7mm or 8mm wires following the TSB for the ignition wire layouts. (critical)
- Cap and Rotor must be of the copper/brass type period. NEVER use the cheap aluminum metal material.
- Cap needs a vent plug. Reduces moisture issues.
- Running with the Purolator L30001 filter for added capacity.
- Using Castrol 5W30 and 10W30 mix non-synthetic at the present.
* Tranny
- ATF+4 only.
* Cooling system
- Replace nearly everything early this year except for the heater cores of the front and rear HVAC systems. All hoses, water-pump, fan viscous clutch, T-stat, radiator, and S-belt.
- A T-stat at 195 helps with fuel MPG. Sure, the 180 t-stats help with performance, but the fuel savings won over the small performance gains. Use a Super Stant for long lasting life. The regular Stants are worthless.
That 19.7mpg still blows my mind thinking about it.
Only two things left to push this van to 20+mpg. Summit Racing has electric water-pumps and eFans for electric cooling the RAD. Of course, I would have to replace the S-belt one more time, but to a non-standard sized one.
David's van had hit the 20mpg mark over a summer ago. It was difficult to believe. He had listed a few things that got his van there. With the steps taken on my van, it seems very realistic.
Of course not all of the items listed were towards MPG gains. Parts failed and needed replacement in the two years. Just glean what you can to help your MPG improvements.
* Brakes
* Exhaust
* Rear Axle
* TB
* Engine
* Tranny
- ATF+4 only.
* Cooling system
They all should have the brass ones, but you need to ask for them otherwise they give you the cheaper aluminum ones. I just bought a brass one last week at Autozone, right off the shelf.
They should outlaw the aluminum contact cap-n-rotor kits totally. They are inferior, poor performers and lessen your gas mileage.
And yes, ask at the counter for the copper/brass contact types. It will cost usually $5 more, but it will pay for itself within an oil change.
Wow I have a 1500 shorten version of your van and best I can get is 13.89 driving like an old lady. Horrible MPG I am going to try some of these things im just not sure where to start or whats going to get the biggest bang for my MPG...
But thanks for giveing a guide gives me some hope that this thing can get better MPG..
But thanks for giving a guide gives me some hope that this thing can get better MPG..
2001
The OD reading is like 80,200 It just turned recently I dont have the PCM or I would check....
Ill switch those out when the PCM gets back im sure they would pay for them self real quick if I even just got 1 or 2 mpg better.
Im also looking at putting this in while I was at it:
http://www.advanceautoparts.com/1/1/...art-45359.html
Trending Topics
2001
Hey, do a search under my name.ID here and look for my radiator/water-pump/t-stat replacement thread. It will help a good deal if you are working in that area. Plenty of pictures to assist too.
The OEM brand actually used in our vans seems to be a Delphi product. These are not cheap, but they are 100% OEM even with the right connectors.
Delphi wasn't the only OEM supplier for the O2 over the years, there were two others.
Look at the connector plug on the pig-tail. Disconnect the connector and look inside, you will understand then.
Hope this helps some.
