1997 Ram Wagon Trans. questions
Old Oct 7, 2011 | 01:41 PM
airborne.pathfinder's Avatar
airborne.pathfinder
Question 1997 Ram Wagon Trans. questions
I just bought a 1997 Ram Wagon 3500 (VIN Z) and I'm getting ready to change the Trans fluid/filter. I figured I should check/adjust bands if it's needed too. Does anybody know what are the specs for the band adjustments and where the adjusters are located?
From what I read, I should use ATF+4 fluid. Is this correct.
I've done this on other vehicles, but I haven't worked on a Van before. I'm planning on pumping the ATF fluid out through the filler tube before I drop the pan. (I have a fluid pump for this. works great.)
Are there any good tips/tricks for doing this?
Old Oct 7, 2011 | 01:49 PM
airborne.pathfinder
Another thought. If anybody knows where I could download a service manual I would be much appreciative. My search efforts end up with prices ranging from $55-$90 for a hardcopy and I'm looking for e-copy or pdf.
Thanks in advance.
Old Oct 8, 2011 | 02:06 PM
Rusty93RamVan's Avatar
Rusty93RamVan
If you'll use the Forum Search function on this subject you will get very specific information as it has been covered recently. If memory serves, Forum Member "alloro" provided the details.
There is also an on-line Chilton manual available -- again, use Search and you will find it.
Welcome to the Forum!
Old Oct 9, 2011 | 05:52 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Here is the band adjustment information: https://dodgeforum.com/forum/dodge-r...tml#post798923
Here is the online Chilton Manual thread: https://dodgeforum.com/forum/dodge-r...e-chilton.html
