Need help with trans
Old Feb 18, 2012 | 02:41 PM
Tony1279's Avatar
Tony1279
Well I guess I have the 46re and as far as I was told he said he replaced the governed sensor when the didn't work he took it to a local shop to have the PCM flashed and he said it wouldn't take idk much about PCMs I have never had any trouble with one. So even if I sent it to sia would I still have to have it flashed to my van
Old Feb 18, 2012 | 06:14 PM
bjr1a's Avatar
bjr1a
The answer is probably , but if you have a security system then definetly....
Old Feb 19, 2012 | 08:39 AM
Tony1279's Avatar
Tony1279
Well it has keyless entry if that's what u mean
Old Feb 19, 2012 | 01:24 PM
master tech's Avatar
master tech
Site Moderator & Tech
I have the PDF files for these codes. If you need them, just ask and I'll send them. All I need is your email address to send them too.
Old Feb 19, 2012 | 09:32 PM
ComicDom1's Avatar
ComicDom1
If you had gone to the SIA website or called them, you would have found out they require your Vin Number and Mileage just in case it is necessary to flash your eprom chip in your PCM. Usually the local shop cannot flash a PCM. It is usually flashed at a Dealer or re-builder like SIA.
Since you keep saying governed sensor I am not clear on what he actually replaced. There is a solenoid pack in the trans which is what the codes you posted were flagging.
Jason
Old Feb 20, 2012 | 06:25 PM
Tony1279's Avatar
Tony1279
Hey I found a PCM on Craigslist my question is can I just plug it in? Or does the donar van have to have every option mine has in order for it to work?
Old Feb 20, 2012 | 10:00 PM
ComicDom1's Avatar
ComicDom1
Tony is the part number the same as the one on yours?
Is it from the same model and year as yours?
Normally when a PCM is re-flashed the dealer or rebuilder requires your Vin number as I mentioned before and also your mileage.
Jason
Old Feb 20, 2012 | 11:30 PM
master tech
Tony
Are you still getting the same codes? And if you don't know what transmission you have, Send me a pm with the last 9 of your vin. I have access to look up vin numbers and recalls.
Old Feb 21, 2012 | 06:52 PM
Tony1279's Avatar
Tony1279
Originally Posted by master tech
Tony
I sent you a pm thanks in advance
Old Feb 22, 2012 | 06:17 PM
Tony1279's Avatar
Tony1279
He replaced the governed pressure solinoid
