Instrument cluster going crazy
Old Jun 5, 2012 | 10:32 PM
gimmeagig's Avatar
gimmeagig
Default Instrument cluster going crazy
I have a 1999 Dodge Ram Van and the following is happening to my instrument cluster.
the brake warning light is on
the check engine light is on
the abs light is on
the speedometer reads nothing until I go faster than about 35mph
the odometer does not advance unless the speedometer is indicating speed.
The truck is running perfectly and the brakes are functioning properly as well.
What might be the cause of all this?
Thank you
Old Jun 6, 2012 | 02:15 AM
sparkzz's Avatar
sparkzz
I dunno, but I had the same thing happen last week (2000 B3500 van). It eventually cleared up, and I assume it is a loose connection somewhere.
Old Jun 6, 2012 | 02:10 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Did you check for any blown fuses?
Old Jun 6, 2012 | 05:21 PM
sparkzz's Avatar
sparkzz
Fuses were all ok. My 2000 van is a high-top built for transporting passengers, and has the schoolbus-door type opening mechanism for loading. Taking the dash panel off to reseat all the connections does not look like it will be easy with the door opening linkage in the way, but since it is working ok now, I'll just think about it for a while longer. LOL
Old Jun 7, 2012 | 12:08 PM
gimmeagig's Avatar
gimmeagig
No, I have not yet. The thought that the warning lights on and an intermittent speedometer could be a blown fuse has not occurred to me. I'll check it out!
Old Jun 24, 2012 | 04:58 AM
ComicDom1's Avatar
ComicDom1
If your dash lights and gauges are going crazy then more than likely the problem is in the PCM.
Old Jun 24, 2012 | 11:20 AM
gimmeagig's Avatar
gimmeagig
What is the PCM? I ssume it's a computer module. Is it expensive and is it difficult to replace?
I have gotten used to the lights being on but I really would like to have my trip meter working again.
Old Jun 24, 2012 | 12:26 PM
alloro's Avatar
alloro
Originally Posted by gimmeagig
What is the PCM?
Powertrain
Control
Module
a.k.a. ECM
Engine
Control
Module
It's under the hood, center above the engine, with 3 large connectors going into it.
Old Jun 24, 2012 | 11:47 PM
ComicDom1's Avatar
ComicDom1
Do a google for SIA electronics in Tilden IL. They will test your PCM and repair it if they can. They have a toll free number and do good work.
Jason
Old Jun 25, 2012 | 11:58 AM
gimmeagig's Avatar
gimmeagig
I need my van for work and I wouldn't be able to take the module out to have it tested and repaired. Unless the van would run without the module installed.
